Yes, that is true which is why mocking up and cycling the suspension is the best answer. If you getting into a suspension rebuild at the same time, then it is easy. If not then it requires you remove the shock and t-bar to get the full range of motion to check fit. Your alignment specs can also have an impact on this as well as large increases in positive caster are going to position the wheel in a different space than negative caster not only while sitting but also through the range of motion. Changes in camber gain and strut rod bushing compression also are factors. Interference with the strut rod and upper control arm are also big factors on a stock suspended car.
