Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Transmission and Drivetrain
(Moderator:
Chryco Psycho
Do really need that spring that goes between the clutch pedal and dash?
« previous
next »
Print
Pages: [
1
Author
Topic: Do really need that spring that goes between the clutch pedal and dash? (Read 1167 times)
Scatterbrain
Jr. Member
1973 Challenger
on:
January 12, 2008 - 12:01:28 PM »
Yesterday pulling out of the parking lot at the golf course the spring that runs between my clutch pedal and the dash broke. I drove the car home and it didn't seem to make a difference. Do I need to have the spring replaced? I thought I read somewhere that it was only needed on cars with diaphram type pressure plates, which mine doesn't have anymore. I kinda like it without the spring as now the pedals sit almost even with each other. Before the clutch pedal sat higher up than the brake pedal.
Logged
73Chally
Resident
Re: Do really need that spring that goes between the clutch pedal and dash?
Reply #1 on:
January 12, 2008 - 12:05:19 PM »
I think the spring might help pull the pedal all the way up in case something hangs up (like mine does and does not always return all the way up), but if you are not having any problems driving it as is, then maybe you don't.
My concern might be that if the pedal does hang up a little bit, the clutch might not fully engage and you will get slippage (is that a real word?).
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
January 13, 2008 - 04:49:51 AM »
the spring does 2 things , it pulls the pedal up at the top of the travel to allow the release brg to stay off the levers extending its life by not turning aall the time & it helps pull the pedal down to lower the preesure needed to depress the clutch pedal , Diaphragms say they do not need the clutch but this has to shorten the life of the release brg
Logged
larry4406
Jr. Member
Reply #3 on:
January 13, 2008 - 08:05:32 AM »
Right or wrong, I did not use the spring when I had a Mcleod borg and beck 3 finger clutch behind my 440. I got about 20k miles on the clutch before the release bearing died and had to be replaced. This was 20+ years ago.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
January 13, 2008 - 02:01:55 PM »
I wouls reinstall it , not fun though
Logged
71chmark
Full Member
Reply #5 on:
January 13, 2008 - 04:09:32 PM »
Quote from: Chryco Psycho on January 13, 2008 - 02:01:55 PM
Stick a couple of screwdrivers between the coils, install the spring, pull them out. That's what I did. Easy.
Logged
I may be schizophrenic,
Killer_Mopar
Sr. Member
Reply #6 on:
January 13, 2008 - 06:46:18 PM »
I took my spring out because I am running a centerforce diaphragm clutch. They are a pain in the ass to remove and I can only imagine a bigger pain to install. I did like 71chmark said and used screwdrivers....good luck with installing a new one.
Logged
FJ5_440
Full Member
Wisconsin
Reply #7 on:
January 13, 2008 - 06:57:00 PM »
An old trick, similar to the screwdriver thing was to use a handfull of big washers and put them between the coils to make the spring longer, then when the spring is put in, step on the pedal and all the washers fall out when the spring expands.
Logged
** Shane **
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
