Author Topic: Drum to disk conversion  (Read 3698 times)
Offline mjb765
« on: January 12, 2008 - 06:53:34 PM »
I have a 70 RT with 4 wheel drums and would like to convert to front disc. Can anyone recommend a reasonably priced complete kit? I don't need state of the art, just a good setup that would include all the needed parts. Any suggestions????
Offline 426HEMI
Re: Drum to disk conversion
« Reply #1 on: January 12, 2008 - 07:07:55 PM »
I will be doing the same to mine.  I have a post in here on this also.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline BIGSHCLUNK
« Reply #2 on: January 12, 2008 - 07:23:25 PM »
I guess my first question is what you consider reasonably priced?   :dunno:  I did an SSBC conversion in the late spring. Nothing too exotic, although I did upgrade to the slotted rotors. Ther nice thing about it is everything FIT! No grinding , hammering, redrilling or any other fit related problems. My biggest mistake was not getting new brake lines (they looked good?) but the fronts were very uncooperative. This was my fault , not the fault of the kit. And would have cut 2-3 hours off the install time!! So if you're gonna do it, call inline tube for some new lines!   :working:
I put around 800 miles on NIKKI tis past summer and have been very happy with it. There was even a situation where they really got "tested"  and I was REALLY HAPPY with them.  Hope this helps.   :burnout:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mjb765
« Reply #3 on: January 12, 2008 - 07:26:03 PM »
I guess somewhere in the $1000 range or there about. What kind of pads are they using and can you get them from anywhere or do you need to go back to SSBC??
Offline BIGSHCLUNK
« Reply #4 on: January 12, 2008 - 07:37:25 PM »
Good question, the calipers are the old mustang style design. so I would think NAPA. On the other hand seeing NIKKI'S basically just a cruiser, and only sees good weather (Wisconsin - roll the dice).  Those pads will probly last me 20 years!   :grinyes:.
BTW with the rotor upgrade and shipping I think I was around $1100. If you want exact numbers I can look in her file.
« Last Edit: January 12, 2008 - 07:39:35 PM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Morris'_Mopars
« Reply #5 on: January 12, 2008 - 07:43:46 PM »
I have four wheel disc brakes from Wilwood.... :2thumbs:
Morris' Mopars LLC
Raymond, Illinois
Mopar performance at affordable prices.
Offline mjb765
« Reply #6 on: January 12, 2008 - 07:44:18 PM »
No need to go crazy looking for the exact price. I am looking into that kit and the wildwood one also. I don't know if the wildwood comes with the master cylinder also though. Did you need to replace the prop valve as well?? I need to find out out what type of pads wildwood uses too.
Offline mjb765
« Reply #7 on: January 12, 2008 - 07:45:07 PM »
what brand pads does it use?? Are they easily available??
Offline BIGSHCLUNK
« Reply #8 on: January 12, 2008 - 07:54:59 PM »
You know, now that I'm thinking about it I believe when I ordered the guy asked me what kind of driving I was doing.  They may have different degrees of pads.  I'm using the stock valve , an additional (and adjustable) valve gets fitted to the line going to the rear. I played with it a bit till I found the setting that felt good to me.  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mjb765
« Reply #9 on: January 12, 2008 - 07:57:05 PM »
I understand that kit comes with a master cyl that will work for either manual or power brakes--am I correct??
Offline 426HEMI
« Reply #10 on: January 12, 2008 - 08:00:32 PM »
I looked at the ssbc site and it comes with a master cylinder.  Most all of the ones I have looked at come with the master cylinder and some will come with a booster as well.  I just want a good setup and not cost an arm and a leg.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline BIGSHCLUNK
« Reply #11 on: January 12, 2008 - 08:03:23 PM »
Nikki's got manual brakes and I kept her that way. When you order you just tell them your intent. And they send the stuff ,not sure if it's the same master tho... I can tell you it's the old tried and true (dare I say ir GM design) and works quite well.  :cheers:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline mjb765
« Reply #12 on: January 12, 2008 - 09:35:41 PM »
Thanks for all the insight. Still torn between the SSBC and the Wildwood. I will make some phone calls and see if the Wildwood master cyl fits power and non power in case I want to add a booster someday. I want to replace the master now but also want to leave the option open. I know the SSBC master fits both. But at least it's narrowed down to 2 kits now. Thanks again.
« Last Edit: January 12, 2008 - 09:42:26 PM by mjb765 »
« Reply #13 on: January 13, 2008 - 04:44:27 AM »
from experience I would use SSBC over Wilwood
Offline mjb765
« Reply #14 on: January 13, 2008 - 09:27:27 AM »
But where do you get replacment pads???? Are they SSBC only???
