Author Topic: Drum to disk conversion  (Read 3700 times)
Offline 426HEMI
Re: Drum to disk conversion
« Reply #15 on: January 13, 2008 - 11:08:14 AM »
I do not think the availabilty of the pads will be an issue.  Just take the new ones that you get and the number of the pads and I think it would be easy to find the pads at any parts store.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
sleepychallenger
« Reply #16 on: January 13, 2008 - 12:13:33 PM »
i got all my stuff from a 73 satellite, cost me a total of about $200
Offline 426HEMI
« Reply #17 on: January 13, 2008 - 01:19:05 PM »
Sounds good and I want to put disk on the rear also.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #18 on: January 13, 2008 - 01:54:25 PM »
73 Satellite would have the floating K frame & taller spindles , not a recommended swap
nivvy
« Reply #19 on: January 13, 2008 - 01:56:52 PM »
I guess my first question is what you consider reasonably priced?   :dunno:  I did an SSBC conversion in the late spring. Nothing too exotic, although I did upgrade to the slotted rotors. Ther nice thing about it is everything FIT! No grinding , hammering, redrilling or any other fit related problems. My biggest mistake was not getting new brake lines (they looked good?) but the fronts were very uncooperative. This was my fault , not the fault of the kit. And would have cut 2-3 hours off the install time!! So if you're gonna do it, call inline tube for some new lines!   :working:
I put around 800 miles on NIKKI tis past summer and have been very happy with it. There was even a situation where they really got "tested"  and I was REALLY HAPPY with them.  Hope this helps.   :burnout:
me too... worked out great and was a true bolt in!!!!!!!
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
« Reply #20 on: January 13, 2008 - 04:51:08 PM »
Keep in mind that the Wilwoods are not an "all weather" design.  Though it is not likely that water could splash past the pads and pistons, but there are no seals there to stop it.
{oo/===\oo}
Offline mjb765
« Reply #21 on: January 13, 2008 - 05:09:17 PM »
OK--I think you guys convinced me---I'll go with the SSBC's....time to go spend money
As ususal this place has helped me again!!!!!!
sleepychallenger
« Reply #22 on: January 13, 2008 - 10:18:21 PM »
works well for me though. dont know what i did but everything turned out well.
i did swap out a that thing that the steering joint bolts into. took it from the drum brakes
« Reply #23 on: January 14, 2008 - 01:33:06 AM »
Take a look @ Scarebird first , they have cheap alternative swaps using common parts
Offline 426HEMI
« Reply #24 on: January 14, 2008 - 11:37:30 AM »
I will have to remember this for sure. Looks pretty good to use.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #25 on: January 14, 2008 - 01:41:54 PM »
The biggest thing is the spindles and caliper adapters. If you can score these at a decent price froma yard or member, then you can get new rotors, calipers, hoses, bearings, seals, at any parts store.
Offline 426HEMI
« Reply #26 on: January 14, 2008 - 01:56:59 PM »
I hope that I can go that way again.  I have done that in the past and converted over.  Maybe someone will have that and let me know.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #27 on: January 15, 2008 - 08:00:11 PM »
not nessisarily , often the calpiers are designed to use a standard production pad , Bear uses the 97 Vette pad for example
I would have tio aks SSBC about what pads fit a given caliper design
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #28 on: January 18, 2008 - 05:09:08 AM »
I have had the scarebird kit for 2 years now and haven't had one problem with them. They feel good and work great. I have right around $250.00 in new parts in the whole conversion and will be doing the rears here soon
Offline 426HEMI
« Reply #29 on: January 18, 2008 - 08:57:38 AM »
That sounds very good.  Thanks for the report.  Looks like that will be the way I go.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
