Author Topic: WTS/WTT BUILT 440/727 READY TO RUN!  (Read 2174 times)
Offline CudaJimmy
« on: January 14, 2008 - 10:48:16 PM »
I was gonna put this 440 in my cuda, but I've decided to go back small block. Will trade motor and trans for similarly built small block with trans or sell outright for $3600 cash.
Here's the specs, pix on request. please email me at cudajimmy@cox.net with trade offers.
71 440 .030
over. srp forged flat tops, comp mechanical flat tappet .540 lift, forged crank .10/.10 clevite 77 bearings, chamfered oil passages,
balanced assembly, shot peened ly rods with all arp hardware on the lower
end. The heads a fresh(have break in time on em) 906 casting W/modified
intake ports (max wedge style), the exhaust ports are huge. The heads were
built by the only guy in are area w/ a flow bench and flow a little over 300
cfm on the intake side @.600 lift, these ports are huge. The intake has
been modified to match the heads so its ported, and welded also. The heads
have 2.14/1.81 valves-ductile iron rockers and hardened shafts, i just ran
all the valves so really all you need is a carb, headers and this
baby will run. The trans is a 727 built by a-1 performance transmisson in
houston, tx. It has a shift kit, raybestos clutches and shifts really firm.
I had the guy modify the valve body a bit so it can be shifted manually all
the time, but w/a kickdown cable it will shift on its own. Have a 3500 converter for this tranny. The shortblock and
tranny have about 900 street miles on them, and 4 passes down hrp in
houston. The short block is really tight i just had the pan off to make
sure it was all good inside, and put a 7 quart pan on it. Oh yea the intake
is drilled for a fogger in case ya like the juice.
Offline CudaJimmy
Re: WTS/WTT BUILT 440/727 READY TO RUN!
« Reply #1 on: January 21, 2008 - 08:07:13 AM »
Bump to top
Offline hemiken
« Reply #2 on: January 21, 2008 - 08:09:45 AM »
I have a stout little 360 and i would trade in a heart beat, except the shipping would kill me. :crazy:
Offline 71chmark
« Reply #3 on: January 23, 2008 - 02:58:35 AM »
Will you separate (no trans) and is the crank drilled for a 4-speed?
I may be schizophrenic,
Offline CudaJimmy
« Reply #4 on: April 20, 2008 - 10:36:24 PM »
Well, the deal I had on my motor trade went south on me this week. We were supposed to meet in St. Louis and I guess he decided to keep his small block. Motor is still up for sale. Will trade for 340 or 360 in similar condition, with or without transmission. I will sell or trade my motor with or without transmission as well. Email me with any questions.
Offline ChallengerGary
    • Challenger Gary
« Reply #5 on: April 23, 2008 - 04:36:28 PM »
What kind of times did you turn when you ran it?  :burnout:
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
Offline 2cudas2go
« Reply #6 on: April 27, 2008 - 09:17:37 PM »
Where are u located?
Some pics of the engine would be great if possible as well.
Offline CudaJimmy
« Reply #7 on: April 28, 2008 - 07:51:00 PM »
It was only raced a few times, but it averaged 12:50 in a c body with a 2:76 rear. That was also with stock 69 hp heads.
Located in OKC and I will be posting some pictures soon.
« Last Edit: April 28, 2008 - 07:53:18 PM by CudaJimmy »
« Reply #8 on: April 28, 2008 - 07:53:59 PM »
 :clueless:  12.50 with 276's    I'd have to see that in a c body
Offline 2cudas2go
« Reply #9 on: April 29, 2008 - 09:07:45 PM »
Is the crank drilled for a 4 speed???
