i would order assembled heads , this will give you valves , seals, retainers, locks & springs , you need all of these , the rockers need to be purchased separately & will not be supplied with the heads , the spring will need to be matched to the cam but getting a spring with just over .600 lift capabilities will be needed if we use one of the cams I typically spec out
