Author Topic: Six Pack Bowl Vent?  (Read 2358 times)
Offline AMXguy
Six Pack Bowl Vent?
« on: January 15, 2008 - 06:04:34 PM »
On My new six pack set up the center carb has a line they call a bowl vent, where does this go on a '70 model? I've seen pictures of '71's with it going to the breather cap but on 70's they didn't or maybe the cars I saw were wrong. did the '70 just not use the hose and leave it open or did it go somewhere else?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Six Pack Bowl Vent?
« Reply #1 on: January 15, 2008 - 06:18:51 PM »
the 70 was open to the atmosphere , & didn`t have the hose pipe on the bowl basically you can just leave it open
Offline AMXguy
« Reply #2 on: January 15, 2008 - 08:11:37 PM »
Sweet, doing nothing is my favorite way of fixing things.
  At idle the bowl vent valve is supposed to be held up and the closes as the throttle is opened right? my carb is new and it's WAY out of adjustment if I'm reading the service manual correct. I can't believe Holley would ship something that far out of whack , makes me wonder if I'm on the right track.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #3 on: January 15, 2008 - 08:40:13 PM »
to my knowledge they only still make the 71 carbs not the 70 style
Offline AMXguy
« Reply #4 on: January 15, 2008 - 08:54:34 PM »
I think you're right because the new ones I have do have the bowl vent tube ( center carb only ). is the adjustment on the vent important? I think mine is screwed up from the factory if it is.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: January 15, 2008 - 08:55:52 PM »
not hugely important as long as it is open at idle
Offline AMXguy
« Reply #6 on: January 15, 2008 - 08:57:12 PM »
By open that would mean up right? or is down open?
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #7 on: January 15, 2008 - 09:00:32 PM »
the arm should move as the throttle  is closed down to idle this will open the vent to allow vapor outside instead of boiling inside the venturis
Offline AMXguy
« Reply #8 on: January 15, 2008 - 09:06:10 PM »
Thanks very much, that's the way I took it from the manual also. I'm surprised Holley would ship a new carb out WAY out of adjustment like that, it was 3/4" from contacting the throttle arm that's why I thought I might be messed up in my thinking .    thanks again
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #9 on: January 15, 2008 - 09:10:18 PM »
the carbs get out of adjustment just shipping them , it may have left the factory set perfectly
 I always reset all adjustments on new carbs
