Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
318 to 440 rad question
« previous
next »
Print
Pages: [
1
Author
Topic: 318 to 440 rad question (Read 1072 times)
darkhawk
Jr. Member
on:
January 16, 2008 - 04:09:44 PM »
I've got a 73 318 car that I'm dropping a 440 into. The old rad is 18 inches and I know I need to upgrade to a 26 inch rad. My question is about the rad supports. I've seen that to fit in the 26inch rad you need the r/h 26 inch rad support. One one site in my travels(of course I can't find it again) It said you only needed the r\h if going from 22 to 26 inch rad. If going from 18 to 26 you will need two of these r/H supports using one for the left side. Anyone else heard this or have any suggestions?
Logged
Nigel
73 Cuda
65 Valiant Convertible
04 Dakota
Chryco Psycho
Administrator
C-C.com Guru
Re: 318 to 440 rad question
Reply #1 on:
January 16, 2008 - 04:24:14 PM »
the 18" rad uses a filler palte to get to the 22" opening so you should have the 22" opening in the rad wall now , so that would only require the right side panel to open up to 26" , a lot of the R/Ts came with 22 rads not 26 so using s tripe core high efficiency 22 " should be enough anyway
Logged
darkhawk
Jr. Member
Reply #2 on:
January 16, 2008 - 04:34:16 PM »
So a 22 inch rad would just drop right in without needing to modify the rad mounts. That sounds great. Maybe I'm getting confused but I thought you needed the 26 rad for the 440 or was that only the hemi?
Logged
Nigel
73 Cuda
04 Dakota
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
January 16, 2008 - 05:44:25 PM »
I know AC dictated 26" , also any HD cooling system , I have seen most 340 with 26" while some 440 R/Ts had 22" , not sure why , Hemi should be 26" as well
Logged
darkhawk
Jr. Member
Reply #4 on:
January 16, 2008 - 05:54:18 PM »
So I could go with either a 22 inch 4 core rad or add the r/h rad support and install a 26 inch rad. Anybody do the r/h rad support install? Do you remove the existing r/h support to add the new one? Just trying to figure out options. I already have a 26 inch rad so that may be the simplest fix.
Logged
Nigel
73 Cuda
04 Dakota
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #5 on:
January 16, 2008 - 06:36:44 PM »
I wish I could offer you advice, but I would feel safer with a 26" rad on a 440.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
January 16, 2008 - 07:00:54 PM »
you will have to remove the right rad wall & install the new panel for 26"
Logged
cowboy
Sr. Member
Denmark
Reply #7 on:
January 17, 2008 - 03:38:18 AM »
I know there is a difference in the in / out from S.b. to B.b.
Can you have both the 22" and the 26" rad, for both B.b and S.b.
Logged
MoPar's for Cruizin, Racing & Pro-touring:
www.CowboyCars.dk
1930 Plymouth Hot Rod wannabe - 1957 DeSoto Fireflite Sportsman - 1967 RaceCuda - 1968 Barracuda - 1971 Challenger R/T Conv.
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
