Author Topic: body code locations on 68 cuda fastback  (Read 1230 times)
Offline mikeinsjc
« on: January 17, 2008 - 01:25:56 AM »
The body code is supposedly stamped in two places on this car. (This is a 68, so the body code and vin are not the same numbers like e-bodies). The primary location is the core support, which I've found. Any ideas where the second is found? Galen Govier says the second can be in one of several locations, but doesn't mention where those locations are. Any ideas?
70 cuda
70 challenger
69 6 pack rr
Offline Ghost
  • I miss my Barracuda :(
Re: body code locations on 68 cuda fastback
« Reply #1 on: January 17, 2008 - 01:56:56 AM »
I think it's in the trunk.
Offline cowboy
  • Denmark
    • CowboyCars.dk
« Reply #2 on: January 17, 2008 - 03:41:06 AM »
 :popcorn:
Alaskan_TA
« Reply #3 on: January 17, 2008 - 08:54:17 PM »
Look under the trunk lid weatherstipping, check the driver's side first. You may be able to feel the "bumps" from the stamped digits on the underside so you know where to pull the weather stripping loose.
