I've been called three times. The first I was called you served for a month. I was picked thfor the Ted Bundy case here in DE. This case was about a guy who killed 13 working ladies along Rt 13 in Wilmington. I got off the case because I worked for DuPont at the time. And DuPont was used to test the fibers in the carpet, plus it was a DuPont carpet. While I escaped that case, I ended up on a civil case that last three weeks learning how to grow mushrooms
Now New Castle County calls you for one day and if you are not pick by 1:30 then they send you home and give you a waiver from duty for two years. Lower DE still has to serve one month.
