Author Topic: What type of screws for rocker gills??  (Read 1568 times)
Offline FJ5_440
  • Wisconsin
« on: January 17, 2008 - 03:31:22 PM »
I would like to attach my rocker gills with the right fastener, but have no idea what the original fastener was.  I have seen them held on with everything from drywall screws to silicone sealer, but would like to know the size and type of fastener originally used.
** Shane **
Re: What type of screws for rocker gills??
« Reply #1 on: January 17, 2008 - 04:45:01 PM »
it should be a stainless countersunk head screw 3/4 " long probably a #8
Offline Winston
« Reply #2 on: February 09, 2009 - 02:48:09 PM »
I see this is a very old thread, but I wanted to get a clarification - I am under the assumption that these '70 rocker gills are held on only by screwing these gills straight to the car, meaning I have to drill holes in the rocker and use self-tapping stainless screws and using no fasteners or clips.  Is this correct?  Thanks for any replies!
I have a '67 Firebird I am also toying with, and these actually have thin metal strips with a lip on the top that screw into the rocker; then the top of the rocker molding hangs on that top lip.  Then you have to drill more holes to mount the bottom of the molding.
I just want to make sure I'm not missing anything.  I'm nervous about drilling holes into the car already, and I want to make sure I am doing it correctly.  Thanks.  :bigsmile:
Offline 'Cuda Hunter
  • Tastes Like Chicken
« Reply #3 on: February 09, 2009 - 02:55:29 PM »
Yep, they are held on with 3 screws I believe.  Several screws less than what the pontiacs take.
I will try to get a pic of a molding.  Do you have the gilled molding already.  That should have a few holes in it.
Offline CudaEd
« Reply #4 on: February 09, 2009 - 03:31:29 PM »
Screws should be Phillips oval head stainless steel sheet metal screws. The rockers need to be drilled and the screws go right into the metal.
http://www.boltdepot.com/sheet-metal-screws.aspx
Good luck!
Offline Winston
« Reply #5 on: February 09, 2009 - 03:34:42 PM »
Hey Josh, hope all has been well with you!  Yeah, I have remanuafactured rocker gills that I have had for a long time.  They are made of fiberglass I think, but they look pretty original from the outside.  The only thing is - I think there are screw holes every 8" or 10".  Not sure exactly, but it is definitely more than 3 screws per piece.  I may have to take a look at the original sets to see how many they have.  Thanks for the information!
Offline Winston
« Reply #6 on: February 09, 2009 - 03:38:11 PM »
Thanks for the comments and link, Ed!
Offline FJ5_440
  • Wisconsin
« Reply #7 on: February 09, 2009 - 08:21:12 PM »
I believe that there are nine per side.  I don't have my car handy to count them though.
** Shane **
« Reply #8 on: February 09, 2009 - 08:24:08 PM »
I realized that I am thinking of my gran coupe rockers.  They are aluminum and run horizontal.
I believe that they have 4 holes for screws.  my bad.
Offline CudaEd
« Reply #9 on: February 10, 2009 - 11:17:49 AM »
I counted nine screwoles on each gill. Here's a pic.
Offline Winston
« Reply #10 on: February 10, 2009 - 04:41:11 PM »
Hey Ed,
Thanks very much for posting this picture.  It helps a lot!  I saw in another thread to use a similar silver as the rally wheel body, so I am hoping mine turn out like yours.  Very nice!
Thanks again!
Offline CudaEd
« Reply #11 on: February 11, 2009 - 10:02:06 AM »
Another hint. Mine are the original gills which were in very good condition, except for a few places where the paint had faded. After testing on a hidden spot, I finally used a product called ground coat, by Dupli-Color, which is intended as a base for a system to simulate metallic paint. It turned out to be pretty much exactly the original color, so that's what I used. Use an adhesion promoter.
