Author Topic: solid lifters  (Read 935 times)
Offline common 27
solid lifters
« on: January 17, 2008 - 06:31:46 PM »
  I'm needing to pick up a set of solid  lifters and was looking at Mopar performance which has a sale going on for 6.90 apiece reg. price 8.00. I've never had solid lifters before so don't know a lot about them but in the picture they don't have a oil? groove around the middle of the lifter.Is that normal for solids?  Also I'm getting ready to set up my rockers on my heads.  Crane ductile rockers on new shafts.Should I use the supplied spring to hold them over against each other or should I use a spacer or does it really make any difference? One last thing I was talking about to Daves 70- does a 7 qt. pan hold 7 qts with 1 in the filter or does it hold 6 with 1 in the filter? I guess thats all for now    :clueless:
1970  Challenger Convertible   1968 Satellite Convertible
Re: solid lifters
« Reply #1 on: January 17, 2008 - 10:18:36 PM »
I would love to reply to this but it took me 20 tries & 10 minutes to open this window , something has to be wrong withthe server or something  :pullinghair:
440Source has set of Solid lifters or the Mopar ones will work as well, the spring works fine to keep the rockers apart , what cam are you looking at using ??
Most 7 qts pans have 6 in the pan & 1 in the filter depending on the type of pan used , the Hemi pan is 6 qt total including filter
« Last Edit: January 18, 2008 - 03:32:52 AM by Chryco Psycho »
Offline cudabob496
Re: solid lifters
« Reply #2 on: January 18, 2008 - 03:40:36 AM »
I didn't know you could just pop in some solid lifters on an otherwise stock type engine. I thought you had to have a solid lifter cam, valve springs, push rods, etc etc?
2011 Kawasaki Z1000
Offline hemiken
Re: solid lifters
« Reply #3 on: January 18, 2008 - 04:23:22 AM »
You can't just pop solid lifters in.  How would you adjust your rocker gear  :clueless: I have a buddy who runs a Hydraulic cam with solid lifters but has all the appropriate solid valve gear to go along with the conversion. :2thumbs:
Offline common 27
Re: solid lifters
« Reply #4 on: January 18, 2008 - 06:50:43 AM »
       :iagree:    I do have a new cam to install,I'm rebuilding a BB.Engle KV1 cam
