Author Topic: Will this work in my 73 8 3/4  (Read 2117 times)
Offline darkhawk
« on: January 17, 2008 - 10:48:43 PM »
I saw an ad locally for the following:
1969  8 3/4"   centersection!. 489 case w/ 3:23 gears!. Sure-grip is weak,probably needs rebuild or replace! $300.00.
My 73 was originally a 318 and I'm going with a 440 so I'm pretty sure it had 2:76 gears.  Any thoughts, on the swap or the price?  From what I've read it should work, but is it a good idea?
Nigel
73 Cuda
65 Valiant Convertible
04 Dakota
Re: Will this work in my 73 8 3/4
« Reply #1 on: January 18, 2008 - 01:07:51 AM »
sounds like a decent buy , no reason not to
it should be a cone sure grip which is not rebuildable but if it has a clutch type it coul dbe rebuilt
Offline darkhawk
« Reply #2 on: January 18, 2008 - 09:08:59 AM »
It is a 1969 which according to what I found says that is the only year for the 489 case that is rebuildable(not cone type).  According to the picture in the ad it looks true as long as that is the actual unit.  Is that true?
Nigel
73 Cuda
04 Dakota
Offline FJ5_440
  • Wisconsin
« Reply #3 on: January 18, 2008 - 09:33:11 AM »
Some 69 489 cases came with the clutch type sure grip, but not all did.  Post or send the photo ans somebody here should be able to tell you.  Look for the ring of bolts opposite the ging gear that hold the sure grip unit together.  If there is a ring of bolts there, it is a rebuildable clutch type.
** Shane **
Offline darkhawk
« Reply #4 on: January 18, 2008 - 09:40:58 AM »
This is the picture in the ad.
Nigel
73 Cuda
04 Dakota
« Reply #5 on: January 18, 2008 - 09:48:27 AM »
Is there another picture? We need to see the other side of the ring gear to look at the carrier.
Offline darkhawk
« Reply #6 on: January 18, 2008 - 10:06:12 AM »
That's all I got.  I'm trying to go see it this afternoon. Anything specific I should be on looking for?  From what I've seen it does not look like the cone type.
Nigel
73 Cuda
04 Dakota
Offline FJ5_440
  • Wisconsin
« Reply #7 on: January 18, 2008 - 01:03:51 PM »
If that thing is in nice shape and has a clutch posi, it is a really good deal.  Especially with no shipping.
** Shane **
Offline tactransman
« Reply #8 on: January 18, 2008 - 01:19:49 PM »
Clutch type
Cone type
Terry-tactransman
Union, Mo.
« Reply #9 on: January 18, 2008 - 02:18:14 PM »
cone has a single cross shaft with 2 spider gears ,clutch has a double cross shaft with 4 spider gears
Offline darkhawk
« Reply #10 on: January 18, 2008 - 03:32:28 PM »
I just talked to the seller it is a cone type.  He says the local machine shop has had limited success in rebuilding them.  Anyone else ever hear this?  I'm skeptical but will keep on researching and inspect the unit on Sunday.
Nigel
73 Cuda
04 Dakota
Offline tactransman
« Reply #11 on: January 18, 2008 - 03:41:42 PM »
I wouldn't mess with "rebuilding" one. After "rebuilt" their life isn't as long as original or as strong.
Terry-tactransman
Union, Mo.
« Reply #12 on: January 18, 2008 - 03:52:07 PM »
you can machine the ends off the cones to allow it to work somewhat , you also need to shim up the spring pack , it works for a while
Offline tactransman
« Reply #13 on: January 18, 2008 - 04:15:02 PM »
...............and if it has been machined already in it's life,you are out of luck! :walkaway:
Terry-tactransman
Union, Mo.
Offline darkhawk
« Reply #14 on: January 18, 2008 - 04:43:08 PM »
Is it worth buying and replacing with an Auburn Gear unit?
Nigel
73 Cuda
04 Dakota
