Reverse light woes
Author Topic: Reverse light woes  (Read 2725 times)
Offline DL74cuda
Reverse light woes
« on: February 10, 2004 - 01:11:22 PM »
Recentily swapped 904 to a 727 no problem there however...
Reverse lights come on and stay on
work in reverse (good thing)
go off in neutral (okay)
come on in drive 1st and second (not good)
Have replaced neutral safety switch as well as harness
replaced ignition switch and turn signal switch (if they matter in this)
Am stumped
Can't find a wiring diagram for car 74 cuda
HELP!!!! any and all constructive suggestions will be entertained.
Re:Reverse light woes
« Reply #1 on: February 10, 2004 - 11:34:22 PM »
What year tranny is the 727?
The valve body may be incompatable with the 3 prong switch
Offline DL74cuda
« Reply #2 on: February 11, 2004 - 09:46:36 AM »
Tranny out of a 71 Dodge Polara it had same type plug if I remeber correctily.
« Reply #3 on: February 11, 2004 - 11:58:39 AM »
71 uses the 3 prong plug & should be fine
Offline DL74cuda
« Reply #4 on: February 11, 2004 - 03:31:48 PM »
Well I know it should be fine, hence the problem ;D
« Reply #5 on: February 12, 2004 - 02:13:04 AM »
I`m not really an expert with Auto trannies , so unless you have 2 sticking switches or the valve body was swapped with the pre 67 one , I`m out if ideas
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #6 on: February 12, 2004 - 02:29:40 PM »
SOUNDS LIKE MAYBE SOME ONE HAS REWIRED THIS ONE.
the two outside pins of the switch is for the reverse lights. one wire should be colored black= 12 volts with the key on, the other should be a black wire with a white line(tracer) on it- this will go back to the rear reverse lights.
the centre is the grounding one for the start relay- only in park and neutral will this pin be grounded to the tranny case.
color=brown with a yellew tracer.
in the tranny is a lever that only engauges the two outside pins if it is in reverse. same for the neutral one.
so take the plug off and check the two outside pins with a ohm meter to see if it only engauges in reverse- get some one to help you move the gear level as you check it.
Hope this helps!!!!
JOHN Mac
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
« Reply #7 on: February 13, 2004 - 08:05:59 PM »
2 more possibilities to check.  Do you have an aftermarket floor shifter?  If so, has the back up lead been run off of it?  2nd poss;  May be a piece of phenolic material in trans where switch screws in.  It seems I ran across both these things on vehicles I have worked on.   Ovmf
'72 Challenger 360,  '05 Dakota,   04 Town & Country,   '82 Yamaha 650 Maxim
Offline DL74cuda
« Reply #8 on: February 17, 2004 - 02:48:02 PM »
Just an update.
It was indeed the phenolic shoe inside the tranny. It had cracked in half and was grounding out. Quick call to Year One for a replacment fixed it.
Thx again for all suggestions
« Reply #9 on: February 17, 2004 - 07:35:34 PM »
Glad to hear yopu got it solved
Offline 71 DEPUTY
    • Cardomain
« Reply #10 on: February 18, 2004 - 07:37:01 AM »
10-4!
