where are the coil placed from the factory 70` E body
Author Topic: where are the coil placed from the factory 70` E body  (Read 1786 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: January 19, 2008 - 01:32:51 PM »
Hi Guys  :swaying:
Can you guys help me out ?
Where was the coil placed originalt on a 70 e body "318 cui". do some of guys have any pictures
Thanks
Dennis
« Last Edit: January 19, 2008 - 02:07:27 PM by Danishmopar »
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Offline 426HEMI
Re: where are the coil placed from the factory 70` E body
« Reply #1 on: January 19, 2008 - 02:50:00 PM »
Sorry no pics but it goes on the back of the intake and mounts close to the dist in a mounting bracket.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline Danishmopar
« Reply #2 on: January 20, 2008 - 02:34:33 PM »
HI  :)
Thanks ...
will try to find a bracket...
Dennis
« Reply #3 on: January 20, 2008 - 08:03:14 PM »
it is a stepped braket , the rear mount is lower then the front
« Reply #4 on: January 20, 2008 - 10:30:11 PM »
Here is one for a 318.
http://cgi.ebay.com/ebaymotors/Mopar-Chrome-Ign-Coil-Bracket-V8-and-6cyl_W0QQitemZ280193141496QQcmdZViewItem?hash=item280193141496
The 340 coil bracket has one foot lower and one higher than the other because the 4 barrel manifold has a higher step up web where one bolt connects one side of the bracket. The 318 original 4 bbl. manifold had very low flat intake runners thus was a flat level mounting pattern.
I know this difference because I worked on the Dodge 318 engines for 4 yrs. in the Army replacing engines and owned a 340 before.
I still have the 340 bracket available. PM me if you decide to go that route.
Offline Danishmopar
« Reply #5 on: January 21, 2008 - 12:18:41 AM »
Hi   :)
I have a aftermarket Waiend intake. I will gonna check for this mounting holes. I`am not sure they are there...
Thanks Guys
« Reply #6 on: January 21, 2008 - 12:25:10 AM »
I can dig up the 340 coil bracket if you need a pic of it.
Offline Danishmopar
« Reply #7 on: January 21, 2008 - 05:47:52 AM »
Hi Guys...
That could be nice. If you has the time for that. Will help me alot  :jumping:
Best regards
Dennis
« Reply #8 on: January 21, 2008 - 10:12:56 PM »
Here you go.  :picture:
340 bracket for an original intake.
Offline Danishmopar
« Reply #9 on: January 22, 2008 - 03:19:47 PM »
HI  :)
Thanks for the nice pictures  :thumbsup:
I have checket my aftermarket intake out and as i can see are there no place to mount that bracket. I think I will go for the firewall mount  :'(
Dennis
Offline 426HEMI
« Reply #10 on: January 22, 2008 - 03:42:10 PM »
That will be ok also just make sure there is enough slack so when the engine torques it does not pull the wire out.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #11 on: January 22, 2008 - 03:52:50 PM »
Mine must not be original then - mine is essentially Q'shaped, just a simple circle that ends in a tab with the other end folded back against the same tab - one bolt goes into the intake.  It's possible that mine isn't original, after seeing the work that an unidentified "Bobby Joe" did on the car before I got it.
Jeff
Offline Danishmopar
« Reply #12 on: January 23, 2008 - 03:31:03 PM »
Thanks guys for all you help  :jumping:
Dennis
« Reply #13 on: January 23, 2008 - 11:43:28 PM »
You're welcome  :2thumbs:
