EYE CANDY …70 challenger 6.1 Hemi & 6-speed updated 6-29 video from Hot Rod
Author Topic: EYE CANDY …70 challenger 6.1 Hemi & 6-speed updated 6-29 video from Hot Rod  (Read 118080 times)
Offline MoparCar
Re: EYE CANDY … 6-SPEED 6.1 Hemi Drop Top!
« Reply #300 on: February 17, 2009 - 08:06:33 PM »
I am going to call quicktime on Tuesday I have ordered the factory bell housing from Dodge but if the quicktime will work, I can keep the starter on the driver’s side instead of moving it to the factory correct passenger side for the new trans. :o
My dealer sold it to me for $2800.00 they said list is like $3800 or something like that.  :drunk:
I did not know they were changing the name of the trans it might be a better swap for shifter selection and drive shaft attachment but I am impatient and didn’t want to wait any longer to get started on setting it up.  :crazy:
Good luck with yours Wes keep me posted.
Thanks for the price and info. Not bad really from the dealer and all. Probably saved shipping also.
The way I understand it from a few is the TR6060 is the same as the T-56 Magnum, just that the magnum will be the non OEM version sort of like the TKO 600 is basically non OEM and it will have a standard T-56 front mount on it for the bell. I might be wrong on this but that's what I was told by Quicktime a while back. Last I looked Quicktime was supporting the GM LS-1/variations of the T-56 and the Viper version for 3G Hemis.
I'm not sure if you have these pictures I've attached. They are from a T-56/6060 installed in Delaney's recent Challenger with the V10. I believe Bill Reilly from Alterkation fame did some of the work. It shows the modified crossmember and the increased tunnel. Also, look at this thread for more details on the parts needed. It's on page 5 here. Bill has a list of parts for the swap, but this it isn't specific for the 3G Hemi. I guess we should be able to buy the pilot and everything straight from Mopar now.
http://www.bigblockdart.com/index.php/topic,23139.120.html
This thread has some info on his speedo connection/issues to the 6060.
http://www.bigblockdart.com/index.php/topic,36148.0.html
Keep us posted.
Wes
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #301 on: February 19, 2009 - 05:09:10 AM »
thanks wes bill makes good stuff I will keep you posted tremic is getting back to me on some stuff also.
 :aarg:
Go Fast & Have Fun...
Offline Bruning Auto Design
« Reply #302 on: February 19, 2009 - 12:12:55 PM »
Definitely give Ross at Quicktime a call.  Last time I checked, the late model hemi specific bell housing will have the starter location on the passenger side, so you may need to use their small block bell housing (extra bolt hole on top).  We're using a small block bell since the late model HEMI bells weren't available.
We're waiting on a new bell housing design from Quicktime for the late model HEMI which will adapt a GM automatic (4L60e/4L65e) for another project in the shop.  Manumatic computer controlled with engine braking and Twist Machine Paddle shifter should do the trick.  My customer didn't want to go the Kiesler route...
Nice work on the TR6060 btw!   :smokin:
    • THE DODGE BOYS
« Reply #303 on: February 20, 2009 - 09:27:15 PM »
Thanks
I called tremec and talked to Jeff the tech guy some good some bad  :pullinghair:
The good  :woo: the t-56 viper is the same bolt pattern as the tr-6060 so I dont have to use the challenger bell, the viper shifter will work (so I dont have to use the remote shifter from the challenger)
The bad  :banghead: no speed  vss (no speedometer drive) some solutions are gps and aftermarket drive shaft sensor. The input shaft is ½ inch longer than the viper t-56 I may have to trim it if I use the quicktime bell instead of the factory bell unless the extra length fits into the crank. Lastly, I will have to come up with a bolt on slip yoke.
 :popcorn:
Offline MoparCar
« Reply #304 on: February 21, 2009 - 09:44:54 AM »
Thanks for the updates. Yeah, I didn't know about the speedo on the 6060 until I read about that over at BBD. I wonder if the T-56 Magnum (6060 aftermarket version) that Tremec will be releasing has a normal speedo and output shaft? I'm going to have to research that part of it.
Appreciate the info.
Wes
    • THE DODGE BOYS
« Reply #305 on: March 29, 2009 - 09:22:56 PM »
I did it                  Ididit
 :working:
     I put my Ididit Colum in Saturday looks cool Pictures coming I know…
I did it I did it  :roflsmiley: :roflsmiley:
    • THE DODGE BOYS
Re: EYE CANDY … I'm DONE SHE"s SOLD!!!!!!!!!!!
« Reply #306 on: April 01, 2009 - 06:01:11 PM »
tHE OL GIRL IS OFF TO A NEW HOME  :walkaway:
Offline NoMope Greg
« Reply #307 on: April 01, 2009 - 06:05:12 PM »
What?  Why?  :eek2:
Or ar you April Foolin' us?  :nono:
« Last Edit: April 01, 2009 - 06:06:56 PM by Greg's HO R/T »
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #308 on: April 01, 2009 - 06:10:41 PM »
 :stomp:  I keep kickin myself for not being able to drive over and meet you. And to see what a beautiful car/cars you were working on.  So I l know I missed seeing a trophy car forsure looking at your pictures.  Hope all is ok for you. :wave:
Offline bb71challenger
« Reply #309 on: April 01, 2009 - 06:18:20 PM »
Gotta be an April Fool's joke. No way you could build that dude and not have a blast in it at least a full summer.  :grinno:   :nono:
*Brett*
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #310 on: April 01, 2009 - 10:45:42 PM »
Ok Scott
Time to tell the truth now!!
2013 Tige' RZR 343hp
Offline dutch
« Reply #311 on: April 02, 2009 - 01:15:37 AM »
yeah, right....  :screwy:
*** Bart ***
    • THE DODGE BOYS
« Reply #312 on: April 02, 2009 - 03:25:28 AM »
April Fools Hoax?
What?  Why?  :eek2:
Ok Scott
 :roflsmiley: :roflsmiley: :roflsmiley: :roflsmiley: :roflsmiley: :roflsmiley:
Yes it was
 :bigsmile:
Just having a little fun my friends I will never get rid of my convertible.
Or should I say “FROM MY COLD DEAD HANDS” you can have my keys.
Sorry not very creative just trying to lighten up things a little around CC things seem to get a little serious from time to time.
Alan no problem my friend we will cross paths someday and go for a cruse together.  :burnout:
« Last Edit: April 02, 2009 - 03:29:18 AM by thedodgeboys »
Offline hemiken
Re: EYE CANDY … 6.1 Hemi Drop Top! No Fooling
« Reply #313 on: April 02, 2009 - 03:39:59 AM »
 :nono: you are a very naughty boy :roflsmiley: i love it.............. :smilielol:
Offline MoparCar
« Reply #314 on: April 13, 2009 - 07:14:44 AM »
I did it                  Ididit
 :working:
Did you use the direct fit e-body or universal for your column? Any pics of the install?
Thanks, Wes
