Time for a little update I guess…
I took some time and paid off some bills so work on the convertible was put on hold until now.
So let’s see I have ordered my wheels they should arrive this week sometime,
my new Elastomeric (Rubber) Bumpers came in last Friday(they need painted),
I swapped out my TR6060 for the more user friendly t-56 magnum ( it’s a hot-rodder’s tr6060) that has a Speedo and a vss output as well as a slip yoke tail housing unlike the not so user friendly one I was going to use.
It has the .50 overdrive gear ratio and the 2.97 first so I am swapping over to 4-10 gears in the new moser mo875 it’s a cool looking setup.
Mounted the hydraulic clutch setup and the remote reservoir this weekend
and cut the tunnel out for the trans that was nerve racking I will weld a new one in next weekend, and the new trans mount.
I need to order a drive shaft Tuesday and a flywheel and clutch setup.
With a little luck I should be up and running by July.
