lack of power?
Author Topic: lack of power?  (Read 6134 times)
Offline hemiken
Re: lack of power?
« Reply #15 on: January 24, 2008 - 03:23:13 AM »
With that combo you have i am geossing it has about 9.0:1 compression and pumping out around the 340-350 HP.  If you where to change nothing but the pistons and bring the compression up to 13.5:1 this will give you something in the range of 420-430 HP.  But more compression yeilds for a lot more to be done on other parts.
A new cam with more compression and a suitable converter will get you pointed in the right direction. :2thumbs:
Not sure what the cam profile is that CP recommended, any chance you could tell us the grind CP old buddy. :clapping:
Re: lack of power?
« Reply #16 on: January 24, 2008 - 03:41:58 AM »
K 56 Engle -272/272* ad - 224/224@ .050 - 110* CL - .504/.504 lift , powerband 1800-5500 rpm , designed to work with 9 :1 compression , decent idle & vacuum
Offline hemiken
Re: lack of power?
« Reply #17 on: January 24, 2008 - 03:43:39 AM »
 :clapping: Like you said CP, it is going to depend on what slugs he has in that thar engine.
 :2thumbs:
Offline Justins72
Re: lack of power?
« Reply #18 on: January 24, 2008 - 03:49:13 AM »
last time i checked the compression i believe it was around 170 to 180 psi, but im not 100% sure on that. I will check it on saturday when i get back home. Now on that cam should i get the heads flow tested to before i pick out a new cam?
Re: lack of power?
« Reply #19 on: January 24, 2008 - 03:49:25 AM »
he may have low compression , a 340 with 8:1 is a dog & it has been rebuilt , a good cam like this can help build a lot of cylinder pressure & fool the engine into thinking it has more compression than it does & will wake it up . I did a 7.8:1 383 a few years back & we ported the heads & installed a Small engle cam &  it became a whole different engine , if he is as low as 8:1 compression the K54 would be a better choice
Re: lack of power?
« Reply #20 on: January 24, 2008 - 03:52:05 AM »
not entirely nessisary to flow test the heads , , most production heads don`t flow great , the best upgrade would be to use the 308 swirl truck heads instead of what you have if you are going to pull the heads & the 308 heads respond well top porting & made 41 RWHP [61 gross HP] gain over X heads on a 340 I worked on
Offline hemiken
Re: lack of power?
« Reply #21 on: January 24, 2008 - 03:56:44 AM »
What you will need to do if you do pull off a head is to pick a piston any piston and put the piston up to the very top of its cylinder.  Now measure with some verniers how far down the bore the piston is and tell us if the piston is flat or dished or better yet take a photo with a digital camera and post it so we can see it.  We then can give you better direction on what needs doing. :2thumbs:
Offline Justins72
Re: lack of power?
« Reply #22 on: January 24, 2008 - 03:12:12 PM »
So the cam you mentioned before would work just fine with the heads i have now even though they have been ported, polished, and had the larger valves put in? i will end up taking the heads off since i have a bad knock on the passenger side that sounds like a stuck lifter, then i can really find out what the compression ratio is.
Re: lack of power?
« Reply #23 on: January 24, 2008 - 03:57:14 PM »
you definatly need to find the noise first
Offline 73Chally
Re: lack of power?
« Reply #24 on: January 24, 2008 - 04:37:00 PM »
 :iagree: This might be a dumb question, but did the noise just recently start?  Could it be something that was on its way to going bad, and that is what was sapping power?
Offline hemiken
Re: lack of power?
« Reply #25 on: January 24, 2008 - 07:20:49 PM »
Holy crap..................... :scared:
What is going on....................... :22yikes:
The more we get involved the deeper the hole seems to be getting. :faint:
Hope everything works out, find that noise and refreshen that little 340 wedge. :jumping:
Offline EVIL72
Re: lack of power?
« Reply #26 on: January 24, 2008 - 08:16:43 PM »
 Here's another one I've been kinda kicking around along with the K54, that is if I just swap out my cam and not just go through the motor on my low compression 73 340. The RPM range seems a little wider on this one. Anyone run one of these cams in a low compression motor?
Brand: Lunati
Product Line: Lunati Voodoo Cam and Lifter Kits #60401LK
Part Type: Camshaft and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,000-5,500
Intake Duration at 050 inch Lift: 213
Exhaust Duration at 050 inch Lift: 220
Duration at 050 inch Lift: 213 int./220 exh.
Advertised Intake Duration: 256
Advertised Exhaust Duration: 262
Advertised Duration: 256 int./262 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.475 in.
Valve Lift with Factory Rocker Arm Ratio: 0.454 int./0.475 exh. lift
Lobe Separation (degrees): 112
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Re: lack of power?
« Reply #27 on: January 25, 2008 - 03:37:46 AM »
the VooDoos are a goiod cam as well & actually have similar specs to the Engles . I would probably go 1 step bigger in most cases
Offline EVIL72
Re: lack of power?
« Reply #28 on: January 25, 2008 - 08:20:23 AM »
 Chryco so your saying on a low compression (1973) 340 Either of these cams will work better than the ones posted above?
638-60402LK
Lunati Voodoo Camshafts
Camshaft & Lifter Kit
Lift: .475''/.494''
Duration: 262°/268°
RPM Range: 1400-5800
Engle K56
4456-H K-56HYD
Valve lift .504
Advertised  Duration 272°
Cam lift .336"
Duration @ .050  224°
Lobe Center 110°
.904" Lifter profile for midrange torque 9 to 1 compression street cars & trucks power from 1800-5500 RPM
« Last Edit: January 25, 2008 - 08:27:26 AM by EVIL72 »
ROB
Re: lack of power?
« Reply #29 on: January 25, 2008 - 01:06:23 PM »
depends how low the compression is , if you know you are under 9:1 the one you listed will work better if you aare near 9:1 the K56 will work better
