TIRE PROBLEM - HELP !
Author Topic: TIRE PROBLEM - HELP !  (Read 1193 times)
Offline 71GRANCOUPE
« on: January 18, 2002 - 04:32:32 AM »
My car has a slow leak in one tire.  These tires have 5k miles on them.
Can the leak be found and repaired?  Also, these cars come with the all mighty bumper jack.  I'd much rather use a floor jack and save the chrome bumper -  where is the best place to locate the floor jack as to not damage the underside of the car?  Is there a good spot on the frame I should be looking for.
The car is solid - no rust- and the tire is on the drivers side front - so the front of the car must be jacked up.
Thanks for the help.
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
Re: TIRE PROBLEM - HELP !
« Reply #1 on: January 18, 2002 - 07:37:53 AM »
i once repaired a tire that had a nail through it.  i also believe if you go to a good tire shop (i use Americas Tires, they are great) they can fix minor leaks and holes no problem.
as for jacking i wouldnt take anything i say about the subject at much value since i dont own an ebod, but on my charger, theres an area right behind each front wheel where two frame rails cross.  looks real sturdy and thats where i always jack up.
« Reply #2 on: January 18, 2002 - 09:18:30 AM »
The "frames" are identical between the E & B bodies. ;)
The best places to lift the car with a floor jack are under the "k" frame or the lower control arms in the front & under the diff housing in the rear ;)
Offline HEMIBULLITT
« Reply #3 on: January 18, 2002 - 01:42:23 PM »
And if ypu're really worried about scratching somethind, use a block of wood with a thick rag on your floorjack.
68 Charger R/T 4spd HEMI
67 Charger 4spd HEMI
70 Challenger R/T SE 440 Auto
http://900z1.multiply.com/
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
« Reply #4 on: January 19, 2002 - 04:12:50 PM »
Yes the wood on the jack would also be my suggestion but if you maybe want to slow the slow leak try rubbing axel greese on the spot of the leak for instance if its a seal problem rub it between the wheel and the rim.
Semper Fi
The Cuda Guy
Member Since January 14, 2002
