Author Topic: Freeze plugs - brass or steel..???  (Read 1289 times)
Offline cowboy
  • Denmark
    • CowboyCars.dk
« on: January 23, 2008 - 10:15:59 AM »
I need some freeze plugs..
Do I choose the brass or the steel ones,  it's the disc type, not the normal cup type...???
Help me get them, - please check the "Help me at NAPA" tread...
Offline 426HEMI
Re: Freeze plugs - brass or steel..???
« Reply #1 on: January 23, 2008 - 10:33:53 AM »
Both are good.  So I would leave it up to you on the look.  They both do the same thing and will last about the same time....
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline bordin34
« Reply #2 on: January 23, 2008 - 10:45:58 AM »
Brass doesn't rust, steel does.
1973 Charger SE Brougham Black 400 auto
1974 Charger SE Brougham Blue 318 auto-SOLD
Offline wally426ci
    • maryland mopars
« Reply #3 on: January 23, 2008 - 11:12:38 AM »
yes definitely use brass!!!!!! its getting painted over anyway! no rust my friend, they use them in boat motors
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #4 on: January 23, 2008 - 12:36:19 PM »
Offline PasiR
« Reply #5 on: January 23, 2008 - 02:10:56 PM »
ALWAYS brass !!
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #6 on: January 23, 2008 - 02:25:21 PM »
Brass still corrodes and oxidizes just like aluminum - it's just not noticeable and still lasts longer than steel.
Jeff
Offline Challenger6pak
« Reply #7 on: January 24, 2008 - 11:52:27 AM »
Jeff
I agree.  I always use brass and antifreeze.  Change out the cooling system fluids occasionally and the brass plugs will last a very long time.
Offline dodge freak 2
« Reply #8 on: January 24, 2008 - 03:41:19 PM »
I hear it the other way, Brass are soft and won't last as long as Steel, the plugs won't rust be will get weak and leak before a Steel plug will-so long as theres no rust.
Brass is for racing motors which get broke down each season--the Brass plugs come out easier. Steel is for street motors that might go 10-15 years without getting pulled. Brass will work in a street motor as long as you don't drive it for 100,000+ miles--like many are.
Factory used Steel, some are 35 years old or more, have 200,000 miles and are not leaking. You need to change the anti-freeze no matter what type of plugs you use. Paint on the outside of the motor stops the Steel from rusting.
« Last Edit: January 24, 2008 - 03:54:38 PM by dodge freak 2 »
« Reply #9 on: January 24, 2008 - 04:05:02 PM »
Maybe it is just an opinion call. One thing about brass is that it will hold better.  You won't blow a brass plug out as easily as a steel one.  This is good and bad.  Good because you can put high pressure on brass in racing aplications.  The bad is a block will crack in the cold easier with brass plugs.
« Last Edit: January 24, 2008 - 04:14:59 PM by Challenger6pak »
