Author Topic: How about these? - Changed my mind - new design (again)...  (Read 6955 times)
Re: How about these? - Changed my mind - new design...
« Reply #15 on: January 24, 2008 - 05:11:17 PM »
Jeff,
   In going aftermarket, keep in mind what backspacing the wheel has.   :grinyes: Not all fit an E-Body.
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #16 on: January 24, 2008 - 07:27:50 PM »
I think I'm going with the second design - I don't think they're too truckish.  A little, but a white car needs somethin' a little more tough lookin' - ya know?
And these are aluminum, so they WILL be lighter.  They're 15", 5-4.5, 19GBS, which is a 5.25" backspacing - should be fine.
I think I'm going to buy one a month - that'll be affordable.  It'll look SO much nicer...
Jeff
Offline hemiken
« Reply #17 on: January 24, 2008 - 07:33:12 PM »
Any chance you can get a picture of the car style wheelfor us to look at Jeff.  The one pictured is a truck rim and the lug nuts throws people off. :2thumbs:
nivvy
« Reply #18 on: January 24, 2008 - 07:49:59 PM »
 :puke:  :2cents:
Offline hemiken
« Reply #19 on: January 24, 2008 - 07:52:07 PM »
Hey Stroker,
Don't hold back buddy, tell us how you really feel. :smilielol:
nivvy
« Reply #20 on: January 24, 2008 - 08:08:01 PM »
Just looking at the picture of the wheels they are not my taste.... however when his car is done they might be the right theme for his car  :2cents:
Offline dougs bs23
Offline go-fish
« Reply #22 on: January 24, 2008 - 09:25:01 PM »
On the MB website they are in the truck/suv section, that means they are heavy duty, that means the are heavy. They have to be heavy in weight because of their intended application, but hey, go for it.
Offline 422STROKER
  • Member Since 6/3/06
« Reply #23 on: January 24, 2008 - 09:50:49 PM »
Make sure a 15"x8 rim with 5.25 BS will clear on the front.  It might but it seems like it would be tight.  Maybe just me. :dunno:
Look truck.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D521%2D5765PS&N=700+4294923106+1004+400304+4294755963+115&autoview=sku
How about these for 99 each?
Tom :dunno:
Tom
Offline 422STROKER
« Reply #24 on: January 24, 2008 - 09:53:36 PM »
They got some like you picked out too.
Tom
Tom
« Reply #25 on: January 24, 2008 - 11:02:41 PM »
The maximum back space you can use with a 15" rim on the front is 4.75. At 5" the wheel lip is into the ball joint. For 17" wheels you have a little bit more room (1") than you do with 15s.
« Reply #26 on: January 25, 2008 - 03:08:33 AM »
I bet you can find some used torque thrusts for cheap , they are everywhere
« Reply #27 on: January 25, 2008 - 07:59:46 AM »
If you want some inexpensive steel wheels that are reasonably light weight, check here;
http://www.speedwaymotors.com/p/196,187_Speedway-IMCA-Approved-Beadlock-and-Non-Beadlock-Wheel-15-x-8-5-on-45.html
proced from $60-100, correct bolt pattern, backspace from 2-5 inches available, come in black, white, chrome, round hole, D hole, or tapered hole designs.
Offline ViperMan
    • JS Custom Cars
« Reply #28 on: January 28, 2008 - 10:15:29 AM »
Alright I can't find these - can you give me a link to them?  I like 'em...
Jeff
**EDIT**  Nevermind, found 'em - Summit 185 Series, but not nearly enough backspacing - only 3.25 inches.  I gotta measure what's on the 'cuda now, but I don't think that's nearly enough.  They'll hit the quarters in the rear.
« Last Edit: January 28, 2008 - 10:17:46 AM by 73Barracuda »
Offline GoodysGotaCuda
« Reply #29 on: January 28, 2008 - 10:21:25 AM »
I'd stick with the prostars or similar. Those last ones look a bit rock crawly to me, its your ride though. if you like 'em, run 'em! I slid by with the 'truck wheels' on my car due to they kinda kept a low key w/o the chrome and my black stripe ties in there.  :cheers:
1976 Dodge Warlock
Wheel & Tire Specs:Link
