Author Topic: Spring rates: AAR vs. Hemi leaf springs  (Read 1274 times)
« on: January 23, 2008 - 09:34:15 PM »
I have brand new AAR, T/A reproduction rear leaf springs, brand new.
I bought em before when I was thinking I would stay with a small block.
Now that I'm going Big block, will the back end sit really high vs. Hemi leafs?
Should I sell these and get a different set that is for a Dana that I plan to buy later?
What are the spring rate differences and traction like in comparison of each other?
Re: Spring rates: AAR vs. Hemi leaf springs
« Reply #1 on: January 24, 2008 - 02:41:47 AM »
the AAR spring s will sit higher & should be slightly softer spring rate , but you have them so why not install them with the 1" lower fornt mount & see fi you like the ride & stance if not it is easy to swap the leafs later
« Reply #2 on: January 24, 2008 - 07:36:45 AM »
Ditto what CP said.
Stock rate on either set is going to be around 130#. The hemi springs just have an extra half leaf to stiffen up the front segment is all. You could alway s add a pinion snubber too if you have some traction issues.
Offline hemiken
« Reply #3 on: January 24, 2008 - 07:40:18 AM »
 :clapping: Actually, If you where smart.  You could always take the springs to a company that builds springs and have them reset yours and add the extra half leaf, you would be surprised how cheap of an excercise this would be. :2thumbs: :working:
« Reply #4 on: January 24, 2008 - 09:42:04 AM »
Would you know who carries them?
I had a feeling they were pretty close to each other on the rate but knew there had to be some kind of difference.
Thank everyone for your input.
« Reply #5 on: January 24, 2008 - 12:35:56 PM »
I have seen them but I forget who builds them , I would contact Frim Feel first they may have them
« Reply #6 on: January 24, 2008 - 01:36:43 PM »
I have a set listed in the parts for sale section.
http://www.cuda-challenger.com/cc/index.php?topic=32550.0
« Reply #7 on: January 24, 2008 - 08:34:51 PM »
HP2 you have a PM
« Reply #8 on: January 25, 2008 - 03:07:37 AM »
Mancinis has the front mounts if anyone else needs them
