Author Topic: Interlock Diagrams Needed!!  (Read 1726 times)
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« on: January 24, 2008 - 01:37:22 AM »
Okay, so my ongoing efforts to put a '74 Challenger dash harness into a '70 Challenger (otherwise know as "Project Square Peg in Round Hole"  ::)) have brought me to the point where I need the '74 wiring diagram for the Interlock System.
Trying to diagnose why Ignition 1, Ignition 2, and the Start function on the ignition switch all cause the starter relay to power on brought me to the bulkhead connector, which is only remotely similar to either the '74 or '70 Challenger diagrams I have.  I got both the diagrams from mymopar.com.
As far as I know, the location #20 should be empty (unless occupied by what I assume is the tach lead), but on mine the dash side has a large yellow wire going to it.  The #9 that should have the yellow wire has two black wires that go into it.  And then there's all kinds of other wires are in different spots, and before I cut the tape off and start rewiring the bulkhead like a 1970 should be, I was hoping for the factory Interlock wiring diagram so I have at least a clue what I'm messing with.
I think there was a button in the engine compartment that let you bypass the seat belt interlock BS in case of problems, and I figure that wiring is what I'm trying to figure out, but I can't find the Interlock Wiring diagram.
To recap:
I'm an idiot for buying a dash off eBay not knowing what it came out of.
I need the Interlock Wiring diagram.
Thanks guys.   :walkaway:
« Last Edit: January 24, 2008 - 01:38:59 AM by RabidScott »
1970 Dodge Challenger
13.9 @ 101 with stock internally 440, OD 4 speed, 3.23 LSD
WaywardGarage.com
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
Re: Interlock Diagrams Needed!!
« Reply #1 on: January 24, 2008 - 09:20:06 AM »
THIS IS THE SIMPLE ONE- Natcho possiably has a factory color code one!
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #2 on: January 24, 2008 - 01:26:46 PM »
Thanks a ton Deputy, that will be helpful when I start pulling wiring, and that confirms my suspicions about the bypass switch wiring going into the engine bay.  I'm pretty sure that's why I have such a different bulkhead connector wiring.
Still looking for the correct wiring diagram for the '74 bulkhead, because the ones I've seen so far are wrong.
WaywardGarage.com
Offline 71 DEPUTY
    • Cardomain
« Reply #3 on: January 24, 2008 - 08:00:31 PM »
one I have is for a b-body- some pics not very clear
Natcho??????
Offline RabidScott
  • Work in Progress
    • waywardgarage.com
« Reply #4 on: January 26, 2008 - 01:47:45 AM »
Okay, well I did some swapping around of a couple wires, and now the ignition works correctly.  Wasn't too hard, really.   :woohoo:
I would still like the correct bulkhead diagram, because I'd like to double check my work.
Many thanks to whomever can step up with the correct information.
WaywardGarage.com
