Author Topic: Info Site for T-Q's  (Read 1059 times)
Offline vinb
Info Site for T-Q's
« on: January 24, 2008 - 08:40:29 PM »
Just in case someone needs any info. on the T-Q's..
http://members.shaw.ca/crussel/thermoquad/tqguide.html
Re: Info Site for T-Q's
« Reply #1 on: January 24, 2008 - 11:27:37 PM »
Thanks vinb...Lotta good info there....here's a another that gets into the tuning aspects
http://australianfordhardtopclub.org/Carter_Thermoquad_info.htm
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #2 on: January 25, 2008 - 01:15:46 AM »
vinb, bullit thanks for the info
bullit in the site that you posted the model code for M/T carb is 9091S
the PO of my Chally give me what he said was the original carb  for the 340 M/T but the #s stamp are 9119S do you think that they stamped the #s  wrong..look at the pic :clueless:
« Reply #3 on: January 25, 2008 - 08:06:43 AM »
9119 77 440 HP AT CA (4027770) 4098 5125 1950 1-1/2 2
9119 appears to be for a later model 77 440
    looking at two different lists I don't see 9091 listed at all..
6318 73 340 MT F /   6339S   1973   340   Manual   w/N98
                         6318 & 6339 seem to be correct for 73 340 manual
   Post a pic of the front & top & maybe we can tell if it looks correct.....  most of them there is very little difference
but I understand the big block versions were higher cfm.
Offline vinb
« Reply #4 on: January 25, 2008 - 04:36:51 PM »
Alot of guys back in the day of the T-Q where switching parts on them. Some of the center bowls where bigger, but all the parts can be interchangeable...
I have about 15 different T-Q's, all need rebuilding and some need the throttle shafts to be bushed.
Complete rebuilding kits are still available from your local parts store.
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #5 on: February 14, 2009 - 10:33:01 AM »
Give the thermoquad doc a call, Demonsizzler is his name on moparts.
Jackson from Toronto.
