Author Topic: Another electrical question dash lights  (Read 1728 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« on: January 26, 2008 - 01:25:40 AM »
When I turn on the headlights the right and left blinker dash lights turn on as well. Any ideas. I think it might be a grounding issue.
1996 Dodge Viper GTS Coupe
Re: Another electrical question dash lights
« Reply #1 on: January 26, 2008 - 02:25:05 AM »
sounds like a ground problem to me
« Reply #2 on: January 26, 2008 - 10:15:21 AM »
One of the left parking lamp filaments could be broken & shorted to the turn signal filament...
I have seen this before.
« Reply #3 on: January 26, 2008 - 11:35:20 AM »
My car had done the same thing. It sat for 32 yrs. I ended up cleaning every ground, taking sand paper to every connection and replacing every bulb and flasher. It works good as new now. Everything went from on to very bright. I also had to make sure the switch pod had the ground screw in it attaching it to the dash.
« Reply #4 on: January 26, 2008 - 02:41:45 PM »
I had that problem when I first bought my car. I think it's trying to tell you a turnsignal bulb is out, but it's not always that simple. In my case, it was a bad ground. I found out the problem was in one of my front parking light housings. 2 of the 3 screw holes were stripped, and it was pretty much dangling by the third. I put in another assembly, and I haven't had the problem since.
Offline 72hemi
« Reply #5 on: January 26, 2008 - 08:50:12 PM »
I will try adding more grounds and checking existing grounds tomorrow. That is kind of what I figured but thought I would see what others thought. My 71 did the same thing, but I never was able to fix that on that car.
Update. I think I have it figured out but I have to go to the parts store. It looks like its the flasher. I'll let you know when I change it if that fixes the problem.
« Last Edit: January 27, 2008 - 01:26:09 PM by 72hemi »
