Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
rad size
« previous
next »
Print
Pages: [
1
Author
Topic: rad size (Read 1778 times)
300
Jr. Member
69 chevelle,67chevelle , 70 barracuda
rad size
on:
January 26, 2008 - 09:13:22 AM »
Hello I have a 70 cuda org 318 car. i,m putting in a 340, what size rad was in each 22" 26" What is the measurement on the rad saddle (width) rough opening, That is for each, i know that if you go to a 26 you can get rad panel ex. Thanks
Logged
hemiken
Sr. Resident
Hemi-fied Mopar in Australia
Re: rad size
Reply #1 on:
January 26, 2008 - 09:17:27 AM »
The radiator sizes have a lot to do weather the car had Air conditioning as well as engine, more so A/C. All you can really do is exactly what you already know by the sounds of things. Measure the opening and if it is 22" you can remove thay side and fit in the new 26" panel for the conversion.
Logged
1970 Barracuda (O^--^===|===^--^O)
1971 Barracuda (O O {]{]{]|[}[}[} O O)
1970 Challenger (O O [======R/T=] O O)
1971 Challenger (O O ===== ===== O O)
300
Jr. Member
Re: rad size
Reply #2 on:
January 26, 2008 - 10:25:41 AM »
Thanks no A/c Manual 340 I could get a good 3 core rad.? I measured the opening 22 in" I guess this is for a 22" in rad
Last Edit: January 26, 2008 - 10:43:02 AM by 300
Logged
Moparal
Permanent Resident
Re: rad size
Reply #3 on:
January 26, 2008 - 11:31:41 AM »
My 70 came with a 318 4 speed. 22" radiator 2 row. I put a fresh 440-6 in it and a 70 383 4 speed 22" radiator in it but got a new 3 row for the tanks. It doesn't over heat at all, but everything is fresh and new.
Logged
common 27
Jr. Member
Re: rad size
Reply #4 on:
January 26, 2008 - 05:23:14 PM »
What does 'remove thay side and fit in the new panel' mean?
Logged
1970 Challenger Convertible 1968 Satellite Convertible
Moparal
Permanent Resident
Re: rad size
Reply #5 on:
January 26, 2008 - 05:37:35 PM »
They make a new radiator side support that converts 22" into a 26" radiator opening...welding required
Logged
FJ5_440
Full Member
Wisconsin
Re: rad size
Reply #6 on:
January 26, 2008 - 08:53:36 PM »
It is good to see the radiator support conversion pieces. That seems much easier than the old method of transplanting in a 26" rad support from a wrecked car.
Definitely cheaper too.
Logged
** Shane **
common 27
Jr. Member
Re: rad size
Reply #7 on:
January 26, 2008 - 09:36:56 PM »
Where can we find this part and what does it consist of to change? Just remove spot welds and reweld in the new piece? Does that also cause the radiator to be offset the 4 inches?
Logged
cudabob496
Sr. Resident
Re: rad size
Reply #8 on:
January 26, 2008 - 10:22:37 PM »
I'd stick in a generic aluminum from Summit. I have one from Howe that cost me about $250 for my 496. Rarely have to turn on the electric fan.
Logged
2011 Kawasaki Z1000
74 340 4speed
Jr. Member
Re: rad size
Reply #9 on:
January 29, 2008 - 01:20:26 AM »
My car still has the 22" rad opening too. I got a custom built aluminum radiator from mancini racing, and it is awesome. The car has a built 340 and has never gone over 180*, even when idling for extended durations of time, or when cruising along at 4,000 rpm. I have a 4.10 gear, so that still isn't very fast, lol. I have no shroud and am using a mopar performance viscous clutch fan package and water pump.
Logged
Andy
1967 Camaro SS: 406 sbc 505 hp/506 ft lbs|4 speed|Posi|3.73s
1969 C/10 350|Turbo 350
1969 Dodge D300 318|4 speed|Dana|4.88s
1972Nova: 350|Turbo 350
1974 'Cuda: 340|4 speed|Dana 60|4.10s|posi
1999 Camaro SS: Auto|Longtube Headers|True Duals|TT2s
2013 Challenger R/T: 6 speed|Hurst with pistol grip|mopar performance exhaust|super track pak
ted
Sr. Member
74 cuda, 70 challenger r/t
Re: rad size
Reply #10 on:
January 29, 2008 - 01:26:41 PM »
non a/c 383s came with a 22" unless it has the max cooling option.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
rad size
