Author Topic: Proportion valve leaks.  (Read 631 times)
Offline loco440
« on: January 27, 2008 - 07:33:38 AM »
I found a brake fluid spot on the driveway from my 70 chall,after a long search I found fluid leaking from what I presume to be the proportion valve or parts there of,it is the small brass block that divides the two front brake lines,the thing that is leaking is a little valve dohiky that sits under this block,you can push this little prong in and out a smidgen and feel the thing is all wet,does any one know what this valve does,if it does nothing I will just braze it up to stop it piddling on my garage floor.
Offline hemiken
Re: Proportion valve leaks.
« Reply #1 on: January 27, 2008 - 07:35:21 AM »
 :clapping: Can you get at it to take a picture.
Offline go-fish
« Reply #2 on: January 27, 2008 - 09:13:48 AM »
I think you are referring to the low pressure sensor for the dummy lite on your dash. I think it's busted if you can push it in.
« Reply #3 on: January 27, 2008 - 03:38:25 PM »
brazing it is not a solution
