ARP bolts
Author Topic: ARP bolts  (Read 1476 times)
Swedefish
ARP bolts
« on: January 27, 2008 - 09:18:20 AM »
I`m upgrading my 383 engine
I wonder if it would be necessary to go with ARP bolts in the shortblock?
calculated CR 9.98
mopar purple 284/484
915 heads with bigger valves
Mopar Muscle did a similair build and they had 451 hp on the dyno.
However, they used a comp cam ,509 lift
Offline hemiken
Re: ARP bolts
« Reply #1 on: January 27, 2008 - 09:20:24 AM »
If you are going to spend the money on bolts, you may aswell buy studs instead for a little bit extra.  But in reality with the compression and cam selection, you really do not need to upgrade the bolts buddy. :2thumbs:
Offline 6packCuda
Re: ARP bolts
« Reply #2 on: January 27, 2008 - 09:53:31 AM »
I would at least put ARP rod bolts. Other than that, you should be ok.
Offline FJ5_440
  • Wisconsin
Re: ARP bolts
« Reply #3 on: January 27, 2008 - 10:38:56 AM »
ARP rod bolts are a must.  I would be careful with using head studs, as Chryco has said the heads cannot be removed while the engine is in the car if head studs are used.  I am not sure if that is true of a 383 but would check into it before using them on a street engine.
** Shane **
Offline CrazyPete
Re: ARP bolts
« Reply #4 on: January 27, 2008 - 11:43:43 AM »
if you dont spend the money for the ARP's at least buy new OEM style bolts gotta remember there 40 years old now
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
Swedefish
Re: ARP bolts
« Reply #5 on: January 27, 2008 - 12:22:21 PM »
Thanks guys
Yes, thats whats crossed my mind too.
I believe that it`s true at least on the drivers side.
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: ARP bolts
« Reply #6 on: January 27, 2008 - 02:08:40 PM »
 kul med andra Svenskar här pâ forumet  :cheers:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: ARP bolts
« Reply #7 on: January 27, 2008 - 04:14:21 PM »
the new rods bolts are a Must ,main stud can be used with ease  head studs are not needed
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
Re: ARP bolts
« Reply #8 on: January 28, 2008 - 09:58:35 AM »
The head bolts are torque-to-yield, aren't they?  Once used and tightened to spec, they cannot be used again.
Jeff
Swedefish
Re: ARP bolts
« Reply #9 on: January 28, 2008 - 10:46:28 AM »
Jeff
So I`ve heard too, but I`ve never replaced any head bolts before.
Hi belgium cuda,
Yeah, we`re quite a few from Scandinavia on here. Gurra Gas used to visit C-C.com too but I haven`t seen him around for a while.
How are things going with your Cuda?
Re: ARP bolts
« Reply #10 on: January 28, 2008 - 12:56:24 PM »
Old engines do not use a torque to yeild head bolt & they can be reused with no issue
 personally I hate the TTY bolts just give me a stronger bolt & a consistant torque setting
Offline dodge freak 2
Re: ARP bolts
« Reply #11 on: January 28, 2008 - 05:19:50 PM »
Some head studs now have a hex shape on top of the stud, this way you can remove the stud in the engine bay.
I was told on new head bolts, thats is only $55 or so, if you can swing it, do it.
