Author Topic: Converting to Manual Steering  (Read 1664 times)
nivvy
« on: January 28, 2008 - 02:02:44 PM »
Just wonderng if any of you have converted from power to manual to free up a belt and some E.T.    :bigsmile:
How much of a gain did yu get??? just wondering if its worth it to me....  :working:   :faint:
looking at Flaming River stuff.......  :swaying:
I know I know...............  :faint:
« Last Edit: January 28, 2008 - 02:05:32 PM by StRoKer »
Offline dodge freak 2
Re: Converting to Manual Steering
« Reply #1 on: January 28, 2008 - 05:16:31 PM »
I never done it but sometimes wish I had. Cleans up the motor bay too. No pump, fan belt.
It depends how you drive it-and how much your G.F. does. In the parking lots you notice it, the faster you go the less noticeable it is. To do it right, you need a wider steering wheel.
« Reply #2 on: January 28, 2008 - 08:46:38 PM »
I like manual steering , never figured out how much power it saves
Offline cudabob496
« Reply #3 on: January 28, 2008 - 10:11:51 PM »
Yep, got lucky and found a manual box for $15 about ten years ago. Dumped the whole power steering system. Must have shed at least 40 or 50 pounds, and I would guess at least 10 hp. Manual steering works fine. Frees up space for big headers too!
2011 Kawasaki Z1000
« Reply #4 on: January 28, 2008 - 10:45:52 PM »
The pump and hoses weigh 40-50 lbs  :clueless:, I would have guessed around 20 lbs.
Is the steering box lighter too?
« Reply #5 on: January 28, 2008 - 11:44:30 PM »
the steering box is much lighter as it is all alum instead of cast iron for power steering
Offline cudabob496
« Reply #6 on: January 29, 2008 - 12:08:47 AM »
The iron pump was like a boat anchor. You could go on line for a complete new power steering system, and check what the shipping weight is, to get an idea.
2011 Kawasaki Z1000
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #7 on: January 29, 2008 - 02:22:36 AM »
Converted mine to manual steering (used one off of a Dart), but I do not have any numbers for you.   :walkaway:
Offline cudabob496
« Reply #8 on: January 29, 2008 - 04:34:25 AM »
Oops, I mean the iron power steering gear, not the pump, was like a boat anchor.
2011 Kawasaki Z1000
nivvy
« Reply #9 on: January 29, 2008 - 05:46:42 AM »
Less Weight and Free up some HP  :ylsuper:
What ALL will I need to convert.... Oh yea... New powersteering box and pump for sale  :money:  :working:
Offline Jacksboys
« Reply #10 on: January 29, 2008 - 01:10:23 PM »
There is an adapter available that will allow you to keep your steering column and just put in a new manual steering unit.  I cannot remember the name right now, but that is what I did and it works great.  Everything else was stock for me.
« Reply #11 on: January 29, 2008 - 01:33:35 PM »
You'll drop a tenth, maybe two, off the e.t. Works great with skinny tires. Anything of substantial width though, and it sucks.
« Reply #12 on: January 29, 2008 - 02:03:24 PM »
Firm feel has the adapter
Offline cudabob496
« Reply #13 on: January 29, 2008 - 07:54:51 PM »
Another great weight saver is to go to Wilwood front disc brakes. I shed 20 lb per front wheel unsprung weight, over my stock Mopar disc brakes. You'll definitely be quicker off the line.  40lbs unsprung wreight!
2011 Kawasaki Z1000
