Brake rotor options `74 Spindes
Author Topic: Brake rotor options `74 Spindes  (Read 2053 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: January 28, 2008 - 04:00:53 PM »
HI  :wave:
I will frishing up my front disk setup on my `70 Challenger "74 spindels" with new calipers and rotores.
But I will hear you guys. are the possible to get some bigger size rotors for my ´74 setup. I think I have the 11" rotors setup now.
Thanks Guys
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Offline Danishmopar
Re: Brake rotor options `74 Spindes
« Reply #1 on: January 28, 2008 - 04:03:23 PM »
Caliper
« Reply #2 on: January 28, 2008 - 08:36:46 PM »
seems the 11.75" rotor can be used with the appropriate adapter & caliper
 read about it  http://www.moparaction.com/Tech/archive/disc-main.html
« Reply #3 on: January 28, 2008 - 08:43:24 PM »
the 11.75" rotor will fit & uses the saem caliper but you need the taller caliper adapter ,, Scarebird has them available
Offline Danishmopar
« Reply #4 on: January 28, 2008 - 11:25:24 PM »
HI :)
I have contacket Scarebird they don`t have them for the 74 spindel setup.
Any idea where I else can get a set of brakets for that setup...
Dennis
« Last Edit: January 29, 2008 - 03:27:19 AM by Danishmopar »
« Reply #5 on: January 29, 2008 - 01:27:35 PM »
The caliper brackets fits any disc brake spindle. However, they bracket wasn't offered until the late 70s until around the mid 80s on large sized cars and heavy duty/police and taxi applications so they werent' available on everything.
Shop around. Post a wanted ad here and on moparts. However, some people think these things are worth gold and I've seen asking prices upwards to $100 a pair. They aren't that valuable. I'll keep my eyes open too as I occasionally run across them in my visits to salvage yards.
Offline Danishmopar
« Reply #6 on: January 29, 2008 - 01:54:54 PM »
HI...
Thanks for the information, it is a good and easy way to get more brake power
Glad to here at you have me in your thoughts  :cheers:
I will make a part wanted here and Moparts...
Best regards
Dennis
« Last Edit: January 29, 2008 - 02:06:00 PM by Danishmopar »
« Reply #7 on: January 29, 2008 - 03:17:29 PM »
does Scarebird have the mount for the slider type caliper instead of the pin type , you can easily get different rebuilt calipers
Offline cudazappa
« Reply #8 on: January 29, 2008 - 06:08:28 PM »
the caliper brackets you are looking for are found on 73 - 78+1/2 B-bodies.  They switched to the slider calipers mid-78 (same as A and FJM and R)
2015 Dart GT - Daily Driver
Offline Danishmopar
« Reply #9 on: February 19, 2008 - 10:05:27 AM »
Hi Guys.
I think at it going to be a success.
Spindels from `74 Challenger
I got the caliper brackets from a 74 roadrunner
The Rotors from 78 Chrysler Cordoba 11,75"
The calipers and horses from `74 Challenger.
What do you guys say are that all wrong  :jumping:
Thanks
Dennis
Offline cudazappa
« Reply #10 on: February 20, 2008 - 06:45:04 PM »
sounds good to me!!  :thumbsup:
Offline GoodysGotaCuda
« Reply #11 on: February 20, 2008 - 06:46:49 PM »
Hi Guys.
Thanks
Dennis
Sorry, but since when did the 74 roadrunner have 11 3/4" brakes? Off the top of my head those caliper brackets wont work with 11 3/4 rotors. Ill have to re-read the article. I'm running 11 3/4s on my cuda, setup from a cordoba
« Last Edit: February 20, 2008 - 06:55:31 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Danishmopar
« Reply #12 on: February 21, 2008 - 12:17:10 AM »
Hi Guys  :cheers:
After a check up at the parts store are I`m not sure with the caliper brackets. As I can see are the not possible to get 11,75" rotors on a `74 road runner. The same GoodysGotaCuda write.
What do you guys says ?
Thanks
Dennis
« Reply #13 on: February 21, 2008 - 08:25:38 AM »
The article states
"The factory finally got their act together in 1976 with the introduction of the 11.75" unicast police rotors....."
So i would certainly start lookin from there.
"...You'll also need a pair of rotors and caliper adapters (a.k.a. brackets) from most any '76-'79 B-body or 79-up R-body (St. Regis, etc.) "
Hope it helps
-Mike
1976 Dodge Warlock
Offline Danishmopar
« Reply #14 on: February 21, 2008 - 04:36:53 PM »
Thanks for all your answers  :thumbsup:
For some time ago i read some place at the `74 Roadrunner will work. But according to the article are i`am wrong  :dunno:
Are there some of you guys there can comfirm that for sure  :)
Thanks guys for a great help.
Dennis
