Author Topic: Need Door Glass hardware part number help pls  (Read 1399 times)
Offline matt63
« on: January 28, 2008 - 05:46:49 PM »
I'm trying to remove the old hardware from my '73 Cuda door glass but 3 of the 4 up stop plugs broke upon removal.  The only source I see is Jim's and they want $20 ea plus shipping.  I'll likley go this route but I thought I would check with the Mopar dealer and see if I get lucky finding some old stock.  Does anyone know what the part number is?  These are the plastic plugs that press into the holes and act as up stops.  A screw is threaded into them to expand the plug and secure it. Thanks.
ps the manual shows some small plastic guides installed on the door glass.  There was no guides on the glass just 2 rollers.  Were the guides instead of rollers??? (there was rollers on the regulator too)
Matt in Edmonton
'68 Valiant
Offline Got JOB
  • Member since 2-14-06
Re: Need Door Glass hardware part number help pls
« Reply #1 on: January 28, 2008 - 06:04:15 PM »
I bought the complete set of slides and rollers from the Paddock. It might not be the same you need but check their on-line catalogue.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline matt63
« Reply #2 on: January 28, 2008 - 06:16:26 PM »
Did it come with the stops?  The kits I saw did not.  I already bought new rollers.  Thanks.
Matt in Edmonton
'68 Valiant
Offline farmboy70
« Reply #3 on: January 29, 2008 - 10:26:15 PM »
The part number should be 2895447 It was use on other moldels also so if you are in a bind you may find it on Bbody glass also.
Offline matt63
« Reply #4 on: January 29, 2008 - 11:48:12 PM »
Thanks!
Matt in Edmonton
'68 Valiant
« Reply #5 on: January 30, 2008 - 10:32:10 AM »
this what you need?....Y1 $4.10++++   Jim's an a-hole stay away.
http://www.yearone.com/serverfiles/part.asp?pid=FD9066&c=0&e=0&cat=1&hid=120AD5168&trk=
Offline matt63
« Reply #6 on: January 30, 2008 - 10:49:43 AM »
No longer available at the dealer - I tried!
Matt in Edmonton
'68 Valiant
Offline matt63
« Reply #7 on: January 30, 2008 - 10:54:15 AM »
Thanks.  Are you sure this will fit the '73 front windows?  It looks similar but they list it for '68-70 so I wonder what's different.
I've heard nothing good about Jim's.  I called and spoke to the woman about the part and she said it was $19.95 ea.  I said the website lists it for $14.95.  They just said too bad it's not been updated.  So much for having to sell for the advertised price.
Matt in Edmonton
'68 Valiant
« Reply #8 on: January 30, 2008 - 11:10:12 AM »
Maybe it's different, I looked at the Pic. at Jim's & they look the same but I suppose they could be a different size. Contact Y1 & see what they say.
    My experience with Jim's was I bought a $60 headliner & on their order form they state
 + shipping & handeling... that turned out to be $39.00...They would not return email complaints....
                                         SCREW JIMS  :villagers:
Offline farmboy70
« Reply #9 on: January 30, 2008 - 09:41:59 PM »
That picture is of the retaining rivit that holds the bracket to the glass on a B body, not the up stop peg that has the larger screw.
Offline matt63
« Reply #10 on: February 04, 2008 - 04:05:27 PM »
Instead of paying $110 for 4 plastic upstop plugs from Jim's, I found these retainers that can be glued to the old up stop plugs.  A screw will hold them together also. I had to buy a box of 25 for $18 from an auto body supply shop and it will be 4 weeks to get them.  This isn't a common problem but it might help someone someday.
Matt in Edmonton
'68 Valiant
« Reply #11 on: February 04, 2008 - 04:49:34 PM »
Great solution....I was thinking that I would fab up something to work given the circumstances.
