Author Topic: Irontires  (Read 1029 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Irontires
« on: January 29, 2008 - 12:53:49 PM »
 My chally feels like a car without suspension and tires made of steel.
 Does the age of the tires have an influence on this?
 Front 235/60 and rear 295/60, new shocks and the rest ok.
 Any bright ideas?  :pullinghair:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Re: Irontires
« Reply #1 on: January 29, 2008 - 01:11:40 PM »
Shocks. Good shocks can make a world of difference in how a car feels. Bad shocks can make even the best combination of parts feel awful.
Offline RusTy/SE
  • Just havin' fun
Re: Irontires
« Reply #2 on: January 29, 2008 - 01:14:04 PM »
Air pressure maybe?
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re: Irontires
« Reply #3 on: January 29, 2008 - 01:54:40 PM »
 Have older hijackers in the rear, tried different airpressures in the shocks
 and in the tires.
Re: Irontires
« Reply #4 on: January 29, 2008 - 02:41:30 PM »
If you have air-shocks, we have found the answer to your problem.   :grinyes:
Re: Irontires
« Reply #5 on: January 29, 2008 - 03:55:04 PM »
 You mean you can get that feeling even if they are not so much pumped up?
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: Irontires
« Reply #6 on: January 29, 2008 - 04:16:18 PM »
Are the shocks from KYB?  I had a set on a car I used to own and hated them.  It felt like I could have removed the springs to make the ride about like.  Trucks should ride like trucks, cars should not.
{oo/===\oo}
Re: Irontires
« Reply #7 on: January 29, 2008 - 06:14:07 PM »
I had air-shocks that were only pumped up halfway. It still road stiff. I went back to regular shocks, and put in new leaf springs to lift the rear the way I wanted it, and it rides much better now. I don't have to worry about the fillings getting knocked out of my teeth if I hit a bump.  :lol:
Offline GoodysGotaCuda
Re: Irontires
« Reply #8 on: January 29, 2008 - 06:24:00 PM »
Air-Shocks are band-aids for wrong spring height, tire sizing, or both. And ride like its on bricks. I just have the summit adjustable drag shocks on the back of my car with s/s springs. Shocks are like $26ea, not too bad of a ride. The fronts are just stock monroes, i'll be swapping out for the summits up front so i can run the 60/40 around town and 90/10 on the strip.
-Mike
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: Irontires
« Reply #9 on: January 29, 2008 - 07:02:22 PM »
 Thanks, will get them Hijackers off. Putted them on years ago due to wrong
 backspace but that's not a problem anymoore.  :2thumbs:
