Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
4C / tti
« previous
next »
Print
Pages: [
1
Author
Topic: 4C / tti (Read 1430 times)
Chryco Psycho
Administrator
C-C.com Guru
4C / tti
on:
January 29, 2008 - 03:49:04 PM »
I talked with Sam today & the center to center measurement on the idler arm should be 5.25" , if it is longer you either have the wrong idler of the fast ratio one
Logged
nivvy
Guest
Re: 4C / tti
Reply #1 on:
January 29, 2008 - 03:51:00 PM »
im gonna go out and measure mine for the sake of it cause I hve aftermarket suspension also.......
Logged
nivvy
Guest
Re: 4C / tti
Reply #2 on:
January 29, 2008 - 04:05:44 PM »
Im getting about 6 1/2 on the idler and pitman center to center....
my stuffs good
All PST suspension stuff........ I run solid motor mounts as well.....
4c didnt you post pics of you fit??? I cant find it......
Last Edit: January 29, 2008 - 04:18:55 PM by StRoKer
Logged
nivvy
Guest
Re: 4C / tti
Reply #3 on:
January 29, 2008 - 04:51:54 PM »
some reference photos for 4c..... its not even close lock to lock........ or straight up on the wheel...
Do you have some sort of small block k member with convert to big block mounts???
mine are 2" TTI's
and the car is completely down on its suspension on all four corners...... you can see the moroso solid motor mounts in the last pic ...
Last Edit: January 29, 2008 - 05:00:05 PM by StRoKer
Logged
nivvy
Guest
Re: 4C / tti
Reply #4 on:
January 29, 2008 - 05:03:50 PM »
found your old pic..... mine is a good 2 1/2+ higher off the arm
does it matter my ride height is lower the whole way around
Last Edit: January 29, 2008 - 05:06:26 PM by StRoKer
Logged
70RT/SE
Jr. Member
I'm a llama!
Re: 4C / tti
Reply #5 on:
January 29, 2008 - 10:32:42 PM »
The 2" TTIs route the tubes differently than the 1 7/8 and 1 3/4 TTI headers. The 2" design has a lot of clearence between the arms and tubes.
You should be able to run fast ratio arms with the 2" headers.
Logged
nivvy
Guest
Re: 4C / tti
Reply #6 on:
January 29, 2008 - 10:59:50 PM »
It is also a good 1/4 inch off the powersteering box....anyone considering getiing tti's just go with the 2" gunbarrels.... look how good the clearance is.....
I hope 4c gets his issues worked out....
Logged
4Cruizn
Administrator
C-C.com Expert
HEMI FISH
Re: 4C / tti
Reply #7 on:
January 30, 2008 - 12:47:12 AM »
I'll get a measurement next time I visit the convertible . . haven't seen it in awhile.
Thanks for checking that out for me CP!
I would like to get it worked out too.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: 4C / tti
Reply #8 on:
January 30, 2008 - 02:12:02 AM »
aYou are welcome , I was talking to Sam anyway & mentioned the problem , we will get it sorted out
Logged
ViperMan
Resident
2017 Carlisle or BUST...
Re: 4C / tti
Reply #9 on:
January 30, 2008 - 12:03:23 PM »
Not to hijack, but geez Stroker - can your oil pan sit much lower?
Jeff
Logged
nivvy
Guest
Re: 4C / tti
Reply #10 on:
January 30, 2008 - 03:39:12 PM »
Quote from: 73Barracuda on January 30, 2008 - 12:03:23 PM
Jeff
I put a STUD girdle on it.... look real close.....
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
4C / tti
