Author Topic: Help with Spec for a 24" enclosed trailer  (Read 650 times)
Offline Confederate Cuda
« on: January 29, 2008 - 04:50:44 PM »
Can you guys help me with what to look for in a 24' enclosed trailer? I will need to buy one within the next two months in PA and my buddy will bring my car in it. What are the things to look for? Jump Door, winch, axel capacity...... I have never owned one and have no idea what to look for so all information is welcomed.
Thanks
Mark
Offline hemi71
Re: Help with Spec for a 24" enclosed trailer
« Reply #1 on: January 29, 2008 - 05:14:26 PM »
Depends what you are going to do with it. If you are going to use it only occasionally, the 7000 lb axles are enough. If you plan on using it more than a few times a year, go with the 10,000 lb axles. I ordered mine with the 7000 lb since i only use it 3-5 times a year, and only load it with a car. ( no golf cart, tool boxes, extra parts, etc) I got the drivers side jump door on mine, well worth the extra $300 as you can get out of the car without having to climb out the window. I had a winch plate installed in mine, then bought a wireless remote control 3500 lb Warn winch and installed it myself. Pulls the car up with no trouble, but again, if i was using the winch on a regular basis, I'd go to a bigger winch. If you are going racin, then you ought to consider a generator package also. If you are in PA, both axles have to have brakes, some states only require one axle brakes. It will need to be inspected once a year also.
I tow using a class 3 reciever, with drop hitch, equalizer bars and a sway control. Dont skimp on the tow setup, no need to try and save a few hundred bucks and lose the trailer and car to an accident. I have a 2000 CTD 2500 fora tow truck, love the diesel, and gets very good mileage towing. I have over 5000 miles on my trailer, I'm pretty happy with it. ( a Haulmark economy, cost me $5300 picked up at the factory by me in 2005)
Offline 426HEMI
« Reply #2 on: January 29, 2008 - 05:18:42 PM »
 :iagree:  with that.  that would be good advice for you.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
« Reply #3 on: January 29, 2008 - 05:55:22 PM »
Thanks
That is great information. I will only use it 4 or 5 times per year and like you it will only contain my car.
