One for the Road - 1970 Challenger T/A Clone
Author Topic: One for the Road - 1970 Challenger T/A Clone  (Read 44076 times)
Offline ShelbyDogg
Re: One for the Road - 1970 Challenger T/A Clone
« Reply #120 on: August 05, 2008 - 08:56:45 PM »
Sam,   The girl.     How much?   (asked in a Borat type accent)
 On to the question!
I'm sorry to to tell you that I hang the quarters THEN try to match the outer wheel houses to them. Sometimes they require some slicing and welding to get them to match up.
 I see that you already welded your outer wheel houses in.     You need to stop welding and tack everything else on to see if you lost your reference points.   Tack or cleco on your quarters and tailpanel. Then lay a decklid on and see if everything squares up.   Taking off as much as you did without building a jig first could have everything off by just a little bit.
« Last Edit: August 05, 2008 - 11:08:18 PM by shelbydogg »
Offline Chlngrcrzy
« Reply #121 on: August 05, 2008 - 10:38:57 PM »
Make sure you lay your trunk lid on top and line it up with your quarters also. Don't ask me why it is important :banghead: :walkaway:
Offline hemiken
« Reply #122 on: August 05, 2008 - 10:43:18 PM »
Good advice from everyone.............. You really need to hang the doors and gap them properly and clamp, screw, cleko or what ever you have on every panel that meets up with the rear quarter panels. :2thumbs:
Offline Samuelson1022
« Reply #123 on: August 06, 2008 - 01:55:14 AM »
Thanks everyone.  Actually right now I dont have the outer wheelhouses welded in as I figured they would have to move.  The only thing I have welded in is the inners on the bottom lip.  I don't have a deck lid at the moment.  Should I get the AMD or the Goodmark?
Offline 71ChallengerSE
« Reply #124 on: August 06, 2008 - 03:00:46 AM »
What happened with the one that was on it before? I went with goodmark and it looks amazing and the fit is near perfect, but im sure AMD is just as good.
Offline hemiken
« Reply #125 on: August 06, 2008 - 03:50:27 AM »
I am pretty sure the AMD one is the one to get :2thumbs:
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #126 on: August 06, 2008 - 06:11:38 AM »
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
« Reply #127 on: August 06, 2008 - 12:52:49 PM »
I pitched the one on it cause it was rot all the way around the lip. Someone told me it would be easier to just get the new one
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #128 on: August 06, 2008 - 09:24:01 PM »
I pitched the one......Someone told me it would be easier to just get the new one
 :faint:
buy new then pitch after your done  :poopoke:
Car is looking great and so is the girl lol
  I have no advise you can use :rofl:
Go Fast & Have Fun...
Offline wally426ci
    • maryland mopars
« Reply #129 on: August 07, 2008 - 09:12:49 AM »
girl? what did i miss?  :stirpot:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline NoMope Greg
« Reply #130 on: August 07, 2008 - 06:44:41 PM »
Apparently, page 8.  :poopoke: :roflsmiley:
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #131 on: August 07, 2008 - 08:21:21 PM »
Offline wally426ci
    • maryland mopars
« Reply #132 on: August 08, 2008 - 11:19:07 AM »
Oh yeah  :dupe:, Cute...  :naughty:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #133 on: August 14, 2008 - 10:08:09 PM »
Well here's everything thrown on just for looks right now.  Its all clamped and when everything is on I plan to get everything just right with clamps, then screws/clekos which I have both.  Ill proceed to yank everything back off and drill for my plug welds.  Then it all goes back on hopefully in the same spot and then welded.  Let me know what I'm missing, cause god knows I spend the majority of my day planning out my next move.  I feel like if I mess up here it aint no pawn goin down but my queen.  But anyways, this is getting exciting!  :ylsuper:
Offline ShelbyDogg
« Reply #134 on: August 14, 2008 - 11:30:21 PM »
I would fit my doors too. That is where you will check your gaps and see what needs to be adjusted. It's hard to tell without them on if the rear raised or lowered.
You should have them on while tacking the rear quarters. They aren't an exact fit, which is what I found out with the AMD firewalls.
