Author Topic: anyone with a t56???  (Read 8539 times)
Offline cttnweary
« on: February 01, 2008 - 12:30:07 AM »
just wondering if anyone has put a t56 in their cuda or challenger? if you have could you please leave some details on the project.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: anyone with a t56???
« Reply #1 on: February 01, 2008 - 01:28:56 AM »
I was thinking about it and talked to keisler. They told me that they could sell me the bell housing but I would have to modify the transmission tunnel to make it fit. I kind of dropped it after that, but I really like the idea of two overdrive gears.
1996 Dodge Viper GTS Coupe
Offline cttnweary
« Reply #2 on: February 01, 2008 - 01:36:54 AM »
hmmm, I wonder how much chopping of the tunnel you have to do? I am pretty sure I am going with a t56 so I would like to find out all involved with this swap.
going to be pretty sweet having 4.11 gears and still be able to cruise the highway and get decent mileage. I get around 31mpg in my 02 ws6 with the 6spd I love it.
Offline 72hemi
« Reply #3 on: February 01, 2008 - 01:42:39 AM »
Is your goal to have a stock appearing car or does that matter. If you have any fabrication experience at all, you can make a new tunnel from scratch and call it a day at that point. Also do you plan on running a stock pistol grip in the stock location or does that matter either.
Offline cttnweary
« Reply #4 on: February 01, 2008 - 03:32:00 AM »
cruising in 6th in my TA I am at 1400rpm's doing 65. that is with stock 3.42 gears.
looking for around 400hp out of the car.
yeah I could have deeper gears and still have usefull overdrive gears
I would like to keep the shifter position as close to stock as possible and I plan on customizing a pistol grip shifter for the project. not too important to keep the car stock appearing, I am doing a 2 tone vitamin C orange/black paint job with some nice 16-17" rims. and since I do custom upholstery the interior is going to be the way I want it.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #5 on: February 01, 2008 - 12:22:59 PM »
That would be a nice tranny to have.  Where can someone get one and how much?
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #6 on: February 01, 2008 - 12:56:43 PM »
I had found them before - I think they were in the 5K range.  I can't find them now.
I did however find this extensive article - didn't have time to read it all myself though.
http://www.hemmings.com/mus/stories/2005/05/01/hmn_feature21.html
Jeff
Offline ViperMan
    • JS Custom Cars
« Reply #7 on: February 01, 2008 - 01:11:02 PM »
Add-On -
I read that Keisler has them - www.KeislerAuto.com - check them out.  I can't find a direct product listing - might have to email them.
I'll try to find more.
Jeff
Offline Carlwalski
« Reply #8 on: February 01, 2008 - 01:39:54 PM »
XV also do a T56 Viper spec box good for WOT shifts at any rpm, all can be shifted like this but this box is supposily built for it eg: you're not going to f#%k it up. Not sure if they've finished fabricating the parts but they do use and have used them on their builds before. Nice box but Scott and I agreed it's more for brag than anything else, unless you like doing 100mph @ 2,400rpm or road race at high speeds a 5-speed box is just as good. If you're keen first place I'd call would be XV. :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
sleepychallenger
« Reply #9 on: February 01, 2008 - 01:44:39 PM »
doesnt keisler offer a 6 speed bolt in kit???
Offline Carlwalski
« Reply #10 on: February 01, 2008 - 01:46:18 PM »
I'm pretty sure that's only for LX based cars, Chargers, 300Cs, etc...... :clueless:
sleepychallenger
« Reply #11 on: February 01, 2008 - 01:47:30 PM »
when they sent me a quote, i think they put the price for the 5 speed and an option for the 6 speed
Offline cttnweary
« Reply #12 on: February 01, 2008 - 02:02:43 PM »
if you know where to look I have seen T56's go for $1k and I know of a site that sells them built to handle 700hp for $2500. I have found the bellhousings for $430.
I still have not decided what engine I am going to use. any suggestions for the best bang for the buck??
Offline ViperMan
    • JS Custom Cars
« Reply #13 on: February 01, 2008 - 02:13:02 PM »
Well you're going with a modern trans, are you looking for a modern engine?
People seem to like the 440>512 Stroker - that's what I'm going to build.  Supposedly good power for reasonable money...
Wanna give more specifics on your project?  What are you hoping to achieve?
Jeff
Offline Confederate Cuda
« Reply #14 on: February 01, 2008 - 02:59:06 PM »
I have one from Kiesler the TKO 600. You will have to cut the tunnel hump slightly. I bought the entire covnersion kit which was $5200 or so. The T56 it's self is not that expensive it the bellhousing that they have to machine that makes it so expensive. Good luck and keep us posted.
