Author Topic: tailpipe location  (Read 521 times)
Offline basement
tailpipe location
« on: February 01, 2008 - 06:11:19 PM »
Does anyone have pics of where the tailpipes are located on their Dodge Rams? I have a friend who is getting a dual exhaust sysem installed on his Rumble Bee and I'm trying to talk him into dropping them in front of the rear tires.
Offline dodge freak 2
Re: tailpipe location
« Reply #1 on: February 01, 2008 - 10:01:17 PM »
IDK but in many states, at least in the past, things keep changing-tail pipes HAD to be behind the rear wheels. Something about keeping those deadly exhaust fumes out of the pass. compartment.
« Reply #2 on: February 01, 2008 - 10:50:01 PM »
I would leave them going out the back. Heat and exhaust aren't good friends with rubber tires over time.
« Reply #3 on: February 02, 2008 - 02:01:23 PM »
the Rumble Bee turn out the side behind the tire , the problem with duals is the moulding under the rear , it is notched on one side fo rth eexhuast , somehow you will need to notch the other side the same
