Author Topic: 275's are on!  (Read 27600 times)
Offline GoodysGotaCuda
Re: 275's are on!
« Reply #15 on: February 06, 2008 - 01:29:36 PM »
whats the backspacing on your rims challorange? you're running 245/?/17s?
Looking to see when i need tires what i can go with, i'll probably need a shorter tire than my 27" talls. those 275s he is running are only 25.6" tall, that little more helps keep my headers off the ground :D
« Last Edit: February 06, 2008 - 01:31:23 PM by GoodysGotaCuda »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #16 on: February 06, 2008 - 01:57:01 PM »
Quote
How about loosening the hinge bolts and pushing the hood down on both sides?
I have spent several hours adjusting the hinges up and down and always end up in about the same shape. At this point I need to know if its the hood or hinges. It has never sat pretty in the hole since I have had the car.
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline 422STROKER
  • Member Since 6/3/06
Re: 275's are on!
« Reply #17 on: February 06, 2008 - 02:12:41 PM »
Goody,
I got the 245/45/17(25.5") on the front now and 255/45/17(26") on the rear but was looking at some 275/50/17's(28") or even some 255/50/17(27") if the 275 were too tall.  But I used to have some 255/70/15(29") so I think the height should be fine on the 275's to clear/look good.
AFAIK the rims  4.5"BS ones, I'll have to check it out for sure.
Tom
Tom
Offline 422STROKER
Re: 275's are on!
« Reply #18 on: February 06, 2008 - 02:14:38 PM »
Yup, tough to tell.  Does it lie flat when completly loose?(hinges)  Or does it always pop up on the other side?  I'm guessing the door to fender gaps are good.
Tom
Tom
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #19 on: February 06, 2008 - 03:39:07 PM »
Its always popped up, have not tried laying it in the hole loose with the hinges removed. Door to fender gaps are ok, the fender to fender measurements are not parallel and were difficult to get them as good as they are. I need to get the hood closing and fairing in better before I start running down the gaps.
I am thinking the hood may be warped or sprung, there is a spot on the top pass side where it looks like someone tried adjusting it by closing it on a board or something. Looking down the side edge, the drivers side looks to have a different profile or shape than the passenger side.
I should start a new thread on this because I know this won't be easily remedied and may require re-adjusting top side of the fenders.
72' Cuda restomod
70 Mustang Mach 1
Offline 422STROKER
Re: 275's are on!
« Reply #20 on: February 06, 2008 - 03:52:50 PM »
Thats where I was going.
Tom
Tom
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #21 on: February 06, 2008 - 03:55:36 PM »
Great minds think alike eh Tom?
72' Cuda restomod
70 Mustang Mach 1
Offline 422STROKER
Re: 275's are on!
« Reply #22 on: February 06, 2008 - 03:58:12 PM »
I don't know about great, but I've been told I think too much. :roflsmiley:
Keep up the great work.  Maybe the hood will work itself out without resorting to major mods.  Either that or you can bolt on an AAR Hood.LOL
Tom :2thumbs:
Tom
Offline 422STROKER
Re: 275's are on!
« Reply #23 on: February 06, 2008 - 04:00:47 PM »
BTW I don't have the centering rings for the rims on mine either, doesn't seem to be a problem so far. :dunno:
Tom :2cents:
Tom
Offline cudagirl4406pk
    • Garageartmusclecars
Re: 275's are on!
« Reply #24 on: February 06, 2008 - 05:07:17 PM »
WEll i just ordered my wheels and tires and i got the following thru http://www.newstalgiawheel.com/
They were very helpful they really know htere stuff i went with
front-235/45/17   with 17x7 rim
rear-255-45-17    with 17x8 rim
I wanted to get that street rod look i got the quailfier wheels and the back spacing is 4.5 in rear and 4.25 in front.On kumo tires.
total was 1863.00 complete ready to bolt on out of the box.
The person i spoke with was David and he said this combo will really give me what i want and no clearance issues.
If you call them they will help you pick your combo and tell you what works and what wont
1-800-281-2819
see ya
michele
also my rally wheels have been sold to winston on this board incase anyone interested.
Offline IMNCARN82
  • LeDZeP
Re: 275's are on!
« Reply #25 on: February 08, 2008 - 09:07:06 AM »
Mayby slot one side deeper. To allow it to go down? Are they the right hinges?  Mine are all the way down in the engine bay. One of the pivots is worn on mine.
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #26 on: February 08, 2008 - 12:30:16 PM »
yes, I think mine are too. I plan to pull the hood and hinges this weekend and will start a new thread based on my findings. Luckily, there is a guy on craigslist that has posted a 70 bulge hood that is close to me. May come in handy if my hood and I have irreconcillable differences.  :smilielol:
72' Cuda restomod
70 Mustang Mach 1
Offline 67Vette427
  • My other car is not a Rambler
Re: 275's are on!
« Reply #27 on: February 08, 2008 - 01:04:19 PM »
Hi All,
Is everybody finding matching tires for the front and the back when they go bigger than 15" rims? I was looking at 17's for the Cuda but I'm having a hard time finding the same tread for front. I've got 255/60R/15's on the back now and the car thinks those are slant 6 Dart tires because they go up in smoke with almost any throttle. I was thinking of going with an 18" x 9.5" rear wheel, custom off set with a 285/40R18 which is the same tire as my Shelby GT500. I'd put the backspace at 4.25 or 4.5" with the stock spring location.
Mike, When I got the Cuda back from the body shop my hood was sticking up on the left side in the rear. I adjusted it flat by bringing the hinge bolt towards the front of the car to its highest point in the slot and the rear bolts to their lowest spots in the slots. The left side adjusted much differently than the right. Be careful because you may get it much lower than you want and it could hit the windshield when you close it. But have somebody lift up on the hood while you work the hinges and do one side at a time. So when you look at the slots the front bolt has very little space on top and the rear's have about 1/2". If this fails you can lower the retainer nuts/slots on the inner fender but that's going to take some welding. Good Luck!
« Last Edit: February 08, 2008 - 02:55:52 PM by 67Vette427 »
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
Re: 275's are on!
« Reply #28 on: February 01, 2009 - 10:57:06 PM »
Hi Mike, I don't remember if you used the 1" or th 1.5" relocation kit from Dr. Diff.    But I was thinking it was the 1.5".   Do you think you could fit the same tire on the rear with the 1" kit?
Thanks,
Chris
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Re: 275's are on!
« Reply #29 on: February 01, 2009 - 11:28:12 PM »
to get the rear of the hood to sit down loosen the hinge bolts & over lift the hood [have someone help ] so the rear of the hinge drops & the front rises snug up the hinge & closse the hood , adjust as nessisary
