Author Topic: 275's are on!  (Read 27599 times)
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #30 on: February 02, 2009 - 06:13:25 AM »
Quote
Hi Mike, I don't remember if you used the 1" or th 1.5" relocation kit from Dr. Diff.    But I was thinking it was the 1.5".   Do you think you could fit the same tire on the rear with the 1" kit?
Thanks,
Chris
I used the 1.5 kit and still had to run a spacer. I could have avoided that by going with a custom BS wheel but I was on a budget and wante to make the stock BS wheel work. Its still close and I need to trim more back fender lip.
Quote
to get the rear of the hood to sit down loosen the hinge bolts & over lift the hood [have someone help ] so the rear of the hinge drops & the front rises snug up the hinge & closse the hood , adjust as nessisary
I need to revisit this, will try this out, thanks CP!
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline WVUFELLA
  • (OO/---------\OO) closest i could for a 72
Re: 275's are on!
« Reply #31 on: April 21, 2009 - 11:01:30 AM »
hey goody... question for ya.... it seems as though most people are going with 17' and i know your running 18's.. I originally wanted 20's but after you recommended not doing so without any airbags or other suspension mods i decided against. I have a stock 72 chally....... but i want to put a wide tire on an 18.... what is the max tire size ,backspace, I can use on an 18 setup...I figured since you already have them you know if a bigger tire can go under with doing any mods..... i have been reading on here but alot of posts just say part of tire size or it has the whole thing but doesnt specify whther they did any mods.... since i am new to the game it is better for me to take someones advice rather than play hit and miss with my lil wallet........ thanks alot (ps anyone with comments please reply I addressed it to him cuz he is the only person i know is running 18's)
Offline 73Chally
Re: 275's are on!
« Reply #32 on: April 21, 2009 - 08:03:37 PM »
Believe it or not a friend of mine is working on a 71 Cuda, and he just put 295/45-18s on the rear, with no rubbing.  there is actually about 1/2" clearance on both sides, with the stock suspension.
Offline WVUFELLA
Re: 275's are on!
« Reply #33 on: April 21, 2009 - 09:03:17 PM »
do you knwo what setup he is running? as far as backspacing or offset? also are cudas and challengers similar in wheelwell space?? thanks for the info .... did he mention what he is doin on the front i just read on goodys page that 18's wont fit on the front...
« Last Edit: April 21, 2009 - 09:09:57 PM by WVUFELLA »
Offline 73Chally
Re: 275's are on!
« Reply #34 on: April 21, 2009 - 09:29:50 PM »
I'll have to see if I can get any more info.  I'm out of town for the week and the car might be gone by the time I get back.
Offline GoodysGotaCuda
Re: 275's are on!
« Reply #35 on: April 22, 2009 - 09:25:00 AM »
I believe it's all posted a  wheel and tire thread if you search. i dont have 18s up front because 18" american racing torque thrusts have smaller center hubs than the 17s. So I'd have to mill the 18s to even bolt onto the car. i have 255/45/ZR17s up front and 295/45/ZR 18s in the rear. 17x8 with 4.5bs up front and 18x9 with 5.9 bs and 7/16" spacers, oh and 3" lug studs to make up for the thick aluminum wheel and spacers.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Re: 275's are on!
« Reply #36 on: April 22, 2009 - 09:26:14 AM »
Thats what I'm running. I believe it.   :grinyes:
1976 Dodge Warlock
Offline WVUFELLA
Re: 275's are on!
« Reply #37 on: April 22, 2009 - 10:59:04 AM »
i ended up going to your website and checking out your specs.... those particular wheels wont allow 18's up front however other wheels might bolt on.... right ?
Offline 73challenger_TN
Re: 275's are on!
« Reply #38 on: April 22, 2009 - 11:05:51 AM »
I believe he also has super stock springs which helps some. I'm running a 255/45/18 on a 18x8 w/ 4.5 backspace. I have a lot of room towards the springs though.
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
Re: 275's are on!
« Reply #39 on: April 22, 2009 - 11:06:35 AM »
Thats correct, you would need a lower profile tire to ge 18's to fit, but they will certainly fit with no problem.  I'm looking at 315/35/18 to go on the back of my challenger.  I have the 1.5" spring relocation kit from Dr. Diff.
295/40/18s will fit fine as well.
check out this link to see what will fit.  http://www.rims-n-tires.com/rt_specs.jsp
Chris
« Last Edit: April 22, 2009 - 11:09:23 AM by PlumCrazyChris »
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Re: 275's are on!
« Reply #40 on: April 22, 2009 - 04:02:24 PM »
I also have 1" lowering blocks, and can go lower without clearance problems. its not much higher, if any than stock in the rear...
1976 Dodge Warlock
Re: 275's are on!
« Reply #41 on: January 01, 2010 - 12:57:52 PM »
Hey Mike, any chance you can update the pics on this thread?
PlumCrazyChris
Round Rock Tx
www.mopar.org
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #42 on: January 01, 2010 - 03:59:05 PM »
sure, lemme see if I can find them
72' Cuda restomod
70 Mustang Mach 1
Offline 71cudajoe
    • 71 Cuda Restoration Project
Re: 275's are on!
« Reply #43 on: January 01, 2010 - 04:45:07 PM »
I'd be interested in seeing the photos also. I'm in the process of making final decisions on tire and wheel combinations for my car. I really like the wheel/tire choice and stance of the Cuda in your avatar photo -- it appears as though your car is lowered. If it is, did you simply adjust the torsion bars on the front to get it down to where you wanted, or did you happen to go with mopar dropped spindles?
David - '71 HEMI Cuda Retro-mod
FOR PICS VISIT www.71cuda.net
Offline miketyler
    • www.miketyler.net
Re: 275's are on!
« Reply #44 on: January 02, 2010 - 08:13:54 PM »
Found em and updated. For comparision, this is what it looked like next to the original 14" wheel I was running:
72' Cuda restomod
70 Mustang Mach 1
