Thanks for the pics Mike. I love the look of them. I hope I can get 315s or at least 305s on the 9.5x18" rims I bought. We'll see.
Tommy, go ahead and lower it as it sits with an airgun, no problems.
But if you need to raise it, be sure and take the weight off the front wheels (stress off the adjusting bolt). They are a LOT harder to lift the car and I've seen bolts that were sheared off from too much torque.
I had to play with the adjustments on mine to get them even. Going back and forth from right to left, adjust one side, bounce it up and down, then that changes the other side some. Bounce it up and down between adjustments, and keep measureing both sides till you get them both were you want them.
Then get it aligned. Firestone has a lifetime alignment that I've used several times when I make changes to my front end. Its only about $30 more then the regular alignment, so its definately worth it, if you ever plan on any upgrades down the road.
