Author Topic: Need to locate factory rivets for 70 Challenger grill  (Read 2122 times)
Offline mikeinsjc
« on: February 02, 2008 - 10:34:14 AM »
My 70 Challenger grill has returned from the anodizers, and I have it held together temporarily with nuts and bolts. Does anyone know where I can get the original factory rivets? I'm not sure rivets is the right word, as they don't seem to be regular rivet gun type of fasteners. Thanks.
70 cuda
70 challenger
69 6 pack rr
Re: Need to locate factory rivets for 70 Challenger grill
« Reply #1 on: February 02, 2008 - 10:50:05 AM »
not sure shat you need but http://www.totallyautoinc.com/ lists a 46 pc grille kit
click parts  then  specialty fasteners  then   grille kits
Offline 1970RTSE
« Reply #2 on: February 02, 2008 - 01:17:11 PM »
I assume you are talking about the rivets that hold the various pieces together.  They are not pop rivets that you can buy at Autozone.  McMaster Carr or MSC Direct has them.  You also need the special tool.  See page 3229 on the online catalog for McMaster Carr.
Offline 70challrtse
« Reply #3 on: February 02, 2008 - 04:34:21 PM »
Try Pete Bloather of Pete's Resto in California.
Offline filmsurgeon
  • Resto-Mod '70 Convertible Challenger
« Reply #4 on: February 25, 2008 - 01:54:55 AM »
I am also in the middle of my own DIY '70 Challenger Grill resto and will need the rivets for assembly.  I Googled Pete Bloather and Pete's Resto, but got nothing (by the way, I'm in SoCal).  I don't think the kit at TotallyAutoInc contains the rivets, just the mounting hardware.  This place ( http://www.hansonrivet.com/ ) should have the rivets and the tool.  Just need to know the exact size and type.
1970 Challenger Convertible (JH27N0B); Resto-Mod; 605 HP, 412cid Small Block; Holley 750CFM Carburetor; A-833 23-spline 4-SPD; A-body 8.75 rear-end w/3.55 gears; 3" mini-tub; leaf spring relocation kit with split-leaf mono and Caltracs; American Racing AR500 Wheels, Rears = 15x10 (5.5" BS) with 315/60-15 BFG Comp T/A Drag Radials; Fronts = 15x7 (3.5" BS) with 215/70-15 BFG Radial T/A Radials.
Offline Code3
« Reply #5 on: December 15, 2014 - 06:21:39 PM »
Did you ever find the rivets and the tool? I'm restoring mine and can't find anyone who successfully found them yet.
Offline JayBee
« Reply #6 on: December 15, 2014 - 07:39:49 PM »
I bought these 1/8 x 3/16 semi tubular rivets to attach lenses onto a rallye light bar.
http://www.ebay.com/itm/25-Semi-Tubular-1-8-by-3-16-Tonka-Structo-Nylint-Rivets-/371205877881?pt=Diecast_Vehicles&hash=item566d983079
I took a couple to my friend's who is also working on a '70 Challenger grille and we test fitted them. He seemed to think they'd work.
I also had to buy a 1/8 rivet clincher to flatten them.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline publicbottle
« Reply #7 on: December 16, 2014 - 02:03:43 AM »
Pete has the correct style rivets and tool you need.
"Try Pete Bloather of Pete's Resto in California."
petedude28
at
yahoo.com
