Author Topic: To rebuild or not to rebuild, that is the question.  (Read 1482 times)
Offline jeryst
« on: February 03, 2008 - 02:17:47 PM »
Cuda's in the body shop, and will be done in another week or so.
Motor is a 340 with 45k miles on it. I was told it was a running vehicle when disassembled.
Should I take the chance of just putting it back in like it is, or should I have it rebuilt or at least refreshed?
Re: To rebuild or not to rebuild, that is the question.
« Reply #1 on: February 03, 2008 - 03:13:42 PM »
valve seals are over 30 yrs old and may end up in the oil pickup tube. Rear main seal is rubber so is the front seal. I'd tear it down and clean it, install new bearings, rings, seals, and a valve job to be assured in your mind. The engine is out and it doesnt cost much right now :2thumbs:
Offline EVIL72
« Reply #2 on: February 03, 2008 - 03:18:38 PM »
 I'd go through it, just to be safe. That way you know for sure it's all fresh.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline GoodysGotaCuda
« Reply #3 on: February 03, 2008 - 03:19:09 PM »
Tear it down
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #4 on: February 03, 2008 - 03:33:47 PM »
It really depends on your budget.   :dunno:
Offline LAA66
« Reply #5 on: February 03, 2008 - 03:35:27 PM »
 I would rebuild it if it were mine. Another thing to consider is it seems every time the motor goes in or out there are new dings and scratches around the engine compartment.
Offline Oldschool
  • Member Since 9-05-06
« Reply #6 on: February 03, 2008 - 03:38:04 PM »
I recommend rebulding it while you have it out....    :bigshades:   If the motor is that old, I have a feeling that you will be doing it before long anyway...  It might run ok for a little while, but like Moparal says, the old brittle rubber will start to crumble and find its way to places it isn't supposed to be....     :working:
Ken  --  In Georgia
Offline jeryst
« Reply #7 on: February 03, 2008 - 03:45:49 PM »
Yea, you guys are probably right. Might as well do it now, while its out.
Can anyone recommend a good rebuild kit?
Might get a little bigger cam while I am at it. Can anyone recommend one that will provide a noticeable lope without requiring a lot of other upgrades?
Offline KellysCuda aircard
  • Its good to be blown
« Reply #9 on: February 04, 2008 - 01:03:47 AM »
I would tear down & check , far easier now than having to pull it again
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #10 on: February 05, 2008 - 09:47:57 AM »
Yeah I agree at least replace the gaskets and seals.  That can never hurt.
As far as rebuild kits, I can't help.  As far as cams, everyone tells me to call Comp Cams and tell them what I have and what I want.
Jeff
Offline 72Bcuda
« Reply #11 on: February 05, 2008 - 10:45:26 AM »
I just went to a custom engine builder to shop a [340/pre 72 360] core to start on (no luck), he warned me to stay away from flat tappet cam setups. Apparently the current oil formualtions are causing havoc with flat tappet wear. Even with additives apparently this is becoming a big problem.
I'm looking at a full roller setup now, I don't have a good reason to go over 6000 rpm.
72 Barracuda - 07 RAM HemiSportQuad - 05 Durango SLT Hemi
« Reply #12 on: February 06, 2008 - 01:20:53 AM »
I never tell you Comp Cams JEFF in fact that would be one of my last choices
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #13 on: February 06, 2008 - 01:28:03 AM »
I would not risk having to install it twice.  At least take it apart and replace all of the seals while checking all of the clearances. Good Luck   :2thumbs:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #14 on: February 06, 2008 - 11:45:30 AM »
A gasket kit is 50 bucks.  Plus you can catch any potential problems now.
Tom  :thumbsup:
Tom
