Author Topic: Adding hidden gauges  (Read 1313 times)
Offline FJ5_440
  • Wisconsin
« on: February 03, 2008 - 06:59:59 PM »
Like many of you guys, I have a tough time trusting the rather vague stock gauges in my car.  I also do not care for the aftermarket gauges hanging down under the dash.  I figured out a way that I could double check the oil pressure and water temp when I am running it hard without having the hot rod look.
I put a pair of autogauge mini gauges where the ashtray was.  I assume most of you guys don't allow smoking in your cars anyway.  I picked up a spare ashtray, and since I wired it with a disconnect harness, it can be swapped out for the stock ashtray in the same amount of time it used to take to empty the ash tray.
They are angled towards the driver for easy visibility and when they are not in use, you just close the ash tray drawer and nothing is visible.
I am planning to add a dual color LED between the two gauge faces to glow red for undercharge and yellow for overcharge so the voltage is monitored as well.
« Last Edit: February 03, 2008 - 07:03:50 PM by FJ5_440 »
** Shane **
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Adding hidden gauges
« Reply #1 on: February 03, 2008 - 07:02:19 PM »
That is a great idea. When I had standard gauges in mine I installed a mechanical oil pressure gauge in the ashtray, and like you said when not in use just close it up.
1996 Dodge Viper GTS Coupe
Offline GoodysGotaCuda
« Reply #2 on: February 03, 2008 - 09:08:37 PM »
Looks good,nice work!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Black340
  • 1973 challenger 340 4 Speed
« Reply #3 on: February 04, 2008 - 12:02:13 PM »
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #4 on: February 04, 2008 - 12:09:30 PM »
Very nice set up!  :thumbsup:  Looks like a very neat install in that little black box.
I remember a friend with like a '70 442 that had little hidden gauges around the interior of his car.  That car I think had like a little storage compartment in the dash somewhere with a lift up cover to hide the gauges.
Offline Finoke
« Reply #5 on: February 04, 2008 - 01:40:36 PM »
Really good idea. I may have to borrow that  :2thumbs:
