Author Topic: K-Frame reinforcements?  (Read 1053 times)
Offline 422STROKER
  • Member Since 6/3/06
« on: February 06, 2008 - 11:35:25 AM »
Ok, while I have my Steering Box and engine out, where should I reinforce the K-frame?  I have read that it flexes by the steering box?  I can't seem to visualize where it should be reinforced. Anyone have an idea or have any of you done it?
Thanks Tom :1zhelp:
Tom
Re: K-Frame reinforcements?
« Reply #1 on: February 06, 2008 - 09:37:07 PM »
I have installed diagonal bracing in side the box in front of the steering box mount DO NOT  go too far forward as the big block oil pump sits in there , I have also tied the mount for the steering box onto the frame better , often the factory welds were not great as well so I go over them where necessary, adding support around the Idler arm on the other side can help as well
Offline 422STROKER
« Reply #2 on: February 06, 2008 - 10:15:40 PM »
Thanks Chryco, You don't have a pic anywhere do you?  I got a small block but will try and keep the bracing inside the open boxes.  I think i'll take a good look at the factory welds in there too.
Tom
Tom
Offline Richie61
  • Pedal to the metal!
« Reply #3 on: February 07, 2008 - 12:14:34 AM »
« Reply #4 on: February 07, 2008 - 06:56:32 AM »
Welding up the factory seams helps loads.
The Firm Feel link has a nice picture of the gusset you can add.
Offline 422STROKER
« Reply #5 on: February 07, 2008 - 07:37:17 PM »
Firmfeel has some photos :bigsmile:
http://www.firmfeel.com/reinfkfram_e.htm
Excellent picture from Firm Feel.
Thank You, now if my welds look that pretty it would be something.LOL
Tom
Tom
