Orginal kickdown linkage and a holley
Author Topic: Orginal kickdown linkage and a holley  (Read 828 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: February 06, 2008 - 03:18:05 PM »
HI Guys
I will hear you guys are the possible to get a conversion kit so my orginal kickdown linkage will bolt on a Holley.
Maybe a picture of the setup   :)
1970 Challenger 318 Cui.
Thanks
Dennis
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Re: Orginal kickdown linkage and a holley
« Reply #1 on: February 06, 2008 - 09:03:59 PM »
I've seen lot's of guys fighting with this issue, seems the 4 barrel as well as the new intake create all kinds of issues with how things relate to each other. Bassically you should be able to move the throttle stud off your OE carb to the Holley but getting all of the linkages to line up and work correctly will take lots of custom work....Easy way out is a kit from http://www.bouchillonperformance.com/BPEtkdcInstructionsNEW.asp
« Reply #2 on: February 06, 2008 - 09:27:43 PM »
the 20-7 carb adapter will help put the pin in the correct position , the manifold may still mount the carb further forward or back or higher so you will still need to adjust usually
Offline Danishmopar
« Reply #3 on: February 07, 2008 - 04:51:36 PM »
Thanks for your answers guys  :thumbsup:
may I ask what a 20-7 carb adapter are  :clueless:
Thanks
Dennis
Offline 73plymouth
« Reply #4 on: February 07, 2008 - 11:38:20 PM »
Thanks
Dennis
Here's a link for you   http://store.summitracing.com/partdetail.asp?part=HLY-20-7
It's just a little arm that adapts the aftermarket Holley carbs to work with the Mopar linkage, they work good :thumbsup:
« Last Edit: February 07, 2008 - 11:39:59 PM by 73plymouth »
« Reply #5 on: February 07, 2008 - 11:49:17 PM »
Thanks 73 P
