Author Topic: Original discbrake  (Read 889 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Original discbrake
« on: February 07, 2008 - 10:29:18 AM »
 There is a lot of threads around converting drums to discs but I wonder if the conversionkit rotors and calipers bolt
 right on if you have original discbrakesystem and original brakebooster - mastercylinder?  :clueless:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Original discbrake
« Reply #1 on: February 07, 2008 - 10:31:47 AM »
I don't know if they will bolt on or not, but if you are just missing those parts, you can purchase them new from places like Kragens (www.cskauto.com) and other parts stores.
1996 Dodge Viper GTS Coupe
« Reply #2 on: February 07, 2008 - 11:48:04 AM »
Most disc brake kits are direct bolt ons. Even things like 13" rotors or the Wilwood and Viper kits all bolt on. There are even a number of rear disc kits that bolt together. Even if you are changing the original disc or doing a drum conversion, all the parts bolt on. If you have disc brake currently and want to upgrade to 11.75" or 13" kits, they still bolt on. Even the racing style aluminum hub kits with seperate rotors all bolt on.
« Reply #3 on: February 07, 2008 - 03:37:34 PM »
 that's good news. Bought new brakebooster and mastercylinder a while ago, do you think they will work with a SSBC kit? :clueless:
« Reply #4 on: February 07, 2008 - 04:32:12 PM »
No reason why they wouldn't.
Offline drewcrane
« Reply #5 on: February 10, 2008 - 11:24:23 AM »
be care ful because wilwood has 2 hubs and one is smaller than the axle hub and one is to big , i put the big one on since it cleared and resulted in a bad vibration , because the hub wasnt centered on the axle , i purchased the shaller one and had to have it machined to fit , and solved a problem i created simply by installing new disc brakes in the rear :2thumbs:
