Author Topic: V8X on Challenger?  (Read 12309 times)
Offline 70 R/T
Re: V8X on Challenger?
« Reply #45 on: December 24, 2008 - 03:27:47 PM »
Thanks Barry,Got that totally wrong,at least you know how it all works,i always thought that if you deleted the R/T side stripe you could have the tail stripe instead. :clueless:
Paul
1970 Challenger R/T
1970 Challenger W.S.S
1965 Chev Impala SS
1969 Chev Camaro RS/SS
1972 Chev Corvette Roadster
1975 Pontiac Trans Am
1985 Chev Corvette
Alaskan_TA
« Reply #46 on: December 24, 2008 - 04:08:28 PM »
Changing from a V6 stripe to a V9 stripe on an R/T was a substitution, not a delete & add the other one, if that helps?
« Last Edit: December 24, 2008 - 04:10:24 PM by Alaskan_TA »
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #47 on: December 24, 2008 - 04:13:16 PM »
70R/T, it's the other way around; the tail bumble-bee stripe is standard, one could choose the R/t side stripe insted or delete altogether.  I never knew about the 'V9x'  though, I assume that this would NOT appear on the fender tag since no drilling is involved.
Alaskan_TA
« Reply #48 on: December 24, 2008 - 04:48:31 PM »
See the page @ the link below.  ;)
http://www.hamtramck-historical.com/images/dealerships/DealershipDataBook/1970/70_Scat_Pack0008.jpg
The V9 stripes were coded on the fendertags.
Offline 70 R/T
« Reply #49 on: December 24, 2008 - 06:56:22 PM »
Ok,thanks guys,were a bit confused last night when i got longitudinal and transverse stripes mixed up ,my challenger has V68,understand how it works now V6--- V9  substitues and will be on fender tag depending on which is chosen and V68 deletes all .thanks  :thumbsup:
Paul
1970 Challenger R/T
1965 Chev Impala SS
1985 Chev Corvette
Alaskan_TA
« Reply #50 on: December 24, 2008 - 07:00:53 PM »
I'll add this just in case anyone is getting the R/T & 340 cars & their standard stripes confused with each other.
V68 - Stripe delete on a R/T
V98 - Stripe delete on a Challenger 340
Offline kissalien
« Reply #51 on: January 26, 2009 - 04:24:19 PM »
Another thing to keep in mind is that starting in February, 1970 the V6 stripes were available on non R/Ts (including the A66 cars). These stripes did not have the R/T callouts, but otherwise looked the same. They were available in Black, White, Red, Blue and Green.
