Author Topic: gas tank  (Read 3299 times)
Offline 1973challenger360
gas tank
« on: February 16, 2004 - 08:11:31 PM »
I got bored today and figured Id take off the gas tank, its was fairly simple with only a few gallons of gas.
the gas looks like coke,  ::) ??? gee that would be great going through a 400.00 carb, I think not.   anyways it is a little rusty inside, I think a sending unit is in the future, but has anyone cleaned there gas tankand coated it with anything work while, what are the 4 lines for and where can I get a new filler gasket on both ends ? oh and a new strap bolt. (it bent)
Im slowly removing a few things under the car and am going to clean it a little better.  I have not yet removed the gasket on the top of the tank but it looks solid and the area above the tank looks great. I will take some picture probably friday.................
Offline BIG MIKE
Re:gas tank
« Reply #1 on: February 16, 2004 - 08:56:46 PM »
take it to a radiator shop, they will clean it with a mild acid tell the to coat it.... i've had many done with no problems..
Re:gas tank
« Reply #2 on: February 16, 2004 - 09:28:10 PM »
thats a great idea what did you pay ?
Re:gas tank
« Reply #3 on: February 16, 2004 - 09:30:20 PM »
has anyone ever put a drain in there tank ?
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re:gas tank
« Reply #4 on: February 16, 2004 - 10:17:33 PM »
Hey 1973, we just finished installing our tank.  You say the strap bolts were bent...those bolts are J bolts and are supposed to look like a "J" and hook into the hole.  Can you take a pic?
As far as the other stuff, there fairly easy to find.  Here's Jacks Auto Part's page with that stuff.  Oh, and they have those j bolts on this page too so you can compare them to yours.
http://www.jacksautoparts.com/catalog/fuel.html
« Last Edit: February 16, 2004 - 11:04:51 PM by Rev-It-Up »
Offline BIG MIKE
Re:gas tank
« Reply #5 on: February 16, 2004 - 10:52:47 PM »
i  think it was around 40.00....
Re:gas tank
« Reply #6 on: February 17, 2004 - 12:10:05 AM »
I bent them, they are twisted a little from the excessive rust in the threads and a breaker bar.
Offline Rev-It-Up
  • Global Moderator
Re:gas tank
« Reply #7 on: February 17, 2004 - 12:20:11 AM »
 ;D ;D  Well that will do it!
Offline BIG MIKE
Re:gas tank
« Reply #8 on: February 17, 2004 - 02:49:33 AM »
 run a die up the threads withpenetrating oil and  helps alot ;) but some bolts can't be helped
Re:gas tank
« Reply #9 on: February 17, 2004 - 02:53:53 AM »
those bolts are long I had to use a wrench for a while until the deep would work not much room, but there easy to get to  :) :) just sit down
Re:gas tank
« Reply #10 on: February 17, 2004 - 04:14:27 PM »
there is a place called suncity radiator 40-45 to dip 35-45 to coat
Offline RusTy/SE
  • Just havin' fun
Re:gas tank
« Reply #11 on: February 23, 2004 - 09:45:26 AM »
Removed my tank also for cleaning/coating at the local radiator shop. The four lines at the front of the tank are vent lines and you should be able to find the filler neck to tank gromett as well as the trunk floor seal at the major resto parts suppliers. I ordered mine from Paddock. Also ordered Tank Tone, Pre Paint Prep and Chassis Black from Eastwood to make things look purrty after reinstalling the tank (and fuel lines).
Russ
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re:gas tank
« Reply #12 on: March 04, 2004 - 04:03:23 PM »
dropped off tank should be done monday.
