Author Topic: Best in the car valve spring compressor?  (Read 1555 times)
Offline AMXguy
« on: February 08, 2008 - 01:46:01 PM »
Anyone have an in the  car valve spring compressor they would recomend? I need one but most of the ones I've seen look like Ronco crap. I need to change out the break in valve seals later this summer and I want a tool that works. thanks
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline vinb
Re: Best in the car valve spring compressor?
« Reply #1 on: February 08, 2008 - 01:53:04 PM »
Go to the site attached.
My friend I raced with makes these for just about all engines.
Nice tool and not too expensive either..
If you call him tell John or Dottie that you know me.....
http://drcraceproducts.com/
Offline AMXguy
« Reply #2 on: February 08, 2008 - 02:07:22 PM »
That is a slick looking tool but I should have said I have a 440, for a hemi that looks like a no brainer way to go.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline vinb
« Reply #3 on: February 08, 2008 - 02:13:12 PM »
He makes them for all Mopar engines big & small. I use it on my small block at the track and works nice...one hand operation....
Go into his site for more info....
Part # 1013....for 440...
Offline AMXguy
« Reply #4 on: February 08, 2008 - 08:26:29 PM »
Now I see it, I'll call him Monday.  thanks
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: February 09, 2008 - 04:44:00 PM »
I have the MAcini tool , it bolts to the rocker stands & levers down , it is the best tool I have even found for doing this , there are different for small & big block but run $70
Offline AMXguy
« Reply #6 on: February 09, 2008 - 06:30:20 PM »
Thanks guys, do you know what size and thread the air fitting for the plug hole is?
 Does everyone put break in seals on with new guides and valves? I'm getting a little smoke but my rebuilder says to run it a few hundred miles more before changing them , I have positive seals by the way. my builder says he'll do it for me but to be honest I'd rather do it myself so I don't have him leaning over my fender and clanking wrenches in by engine bay. great mechanic but not as fussy about looks on a car as I am.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline vinb
« Reply #7 on: February 12, 2008 - 08:33:56 PM »
Mancini Racing # MRE67461 and Comp Cams #5324, those are the one DRC makes for all the companies that sell them.
You should be able to buy direct from DRC.....
Hope that helps...
Offline 4Cruizn
  • HEMI FISH
« Reply #8 on: February 13, 2008 - 12:10:11 AM »
I used it . . .worked great!!  This is one great tool!   :grinyes:
Offline drewcrane
« Reply #9 on: February 15, 2008 - 05:46:52 PM »
i have a night mare olsd school story, i used a valve compressor to change my valve springs , and i used the old school method of using a window sash rope,it is small enough to fit through the spark plug hole, it worked well as the valve didnt slide down in to the hole, however when i went to pull the rope out  it got stuck and would not come out, so i had to remove the head , and low and behold that rope tied it self in to a fishermans knot perfectly so i couldnt get it out with out removing the head  so now i have the air valve to do the job much easier :violin:
