Fitting new booster to Firewall..
Author Topic: Fitting new booster to Firewall..  (Read 1874 times)
Offline Danishmopar
  • 70´ Challenger. Denmark, scandinavien.
    • Overhauling 70´Challenger
« on: February 09, 2008 - 05:28:40 PM »
HI Guys
I have purchaset a new brake booster to my `70 Challenger 318 Cui Born with out booster. But I have a littel problem The booster do not macht up with the holes in the reinforcement plate and the firewall. should i do some modernization to get it on or should bolt right on  :1zhelp:
I have the littel pedal linkage so i could have all the parts to make this conversion.
 :1zhelp:
Thanks Guys
« Last Edit: February 09, 2008 - 05:31:08 PM by Danishmopar »
Work and Supportet your forces at 821st Air Base Group. Thule AB, Greenland
Pictures of My challenger: http://picasaweb.google.dk/dennisogkatja/Overhauling70Challenger#
Re: Fitting new booster to Firewall..
« Reply #1 on: February 09, 2008 - 05:33:45 PM »
the firewall re-enforcement plate is different  for power brakes
 the booster mount moves the booster higher & then uses the double pivot linkage to hook to the pedal
« Last Edit: February 09, 2008 - 05:35:22 PM by Chryco Psycho »
Offline Danishmopar
« Reply #2 on: February 09, 2008 - 05:55:32 PM »
Thanks Chryco Psycho  :)
I can see at I will need a diskbrake reinforcement plate.
I have some holes in my firewall there almost match up with the booster. I think at the earlier owner has drillet them Mayne he has been a littel dizzy.
If my car is born without booster. should i so have booster holes i the firewall or only have a small bolt "pattern" For the master cylinder.
I think at i have the double pivot linkage "picture"
Thanks Guys
« Last Edit: February 10, 2008 - 03:46:56 PM by Danishmopar »
« Reply #3 on: February 09, 2008 - 06:18:58 PM »
the holes for the booster will be in the firewall higher up hidden by the plate which you will need , the double pivot link is the part you have in the picture
Offline Danishmopar
« Reply #4 on: February 10, 2008 - 02:40:21 PM »
Thanks again Chryco Psycho  :thumbsup:
I mountet the booster today after I modernize the Firewall a littel, it came out top nice :thumbsup:
Can you guys tell me are there any difference for 74 e body to 70 e body booster reinforcement plate.
Thanks Guys
« Reply #5 on: February 10, 2008 - 03:19:00 PM »
to my knowledge the plate is the same for all E bodys & 71-74 B bodys as well
« Reply #6 on: February 10, 2008 - 03:58:43 PM »
Manual non power brake re inforcement plate is different than power brake re inforcement plate.
I just went thru the same thing with my OEM Bendix booster.
For my application, I bought the power brake re inforcement plate.
I bought the manual one and after, found out it wasn't the right one.
« Last Edit: February 10, 2008 - 04:39:40 PM by Topcat »
Offline ChallengerGary
    • Challenger Gary
« Reply #7 on: February 11, 2008 - 05:38:14 PM »
Where can you get the power reiforcement plate?  I have the same issue with my 72 RR clone...
2006 Dodge Ram 1500 Mega Cab 5.7 Hemi
1972 Dodge Demon - "new" project
AND TOO MANY OTHER MOPARS THROUGH MY HANDS TO COUNT
« Reply #8 on: February 11, 2008 - 07:39:29 PM »
Try this guy out on e bay. I bought mine from him about a month ago. He had 2 or 3 of them and he still may have some around. His name is Joe.
http://motors.search.ebay.com/_W0QQsassZfuelinjectedfish
« Reply #9 on: February 11, 2008 - 08:42:49 PM »
For the original Hemi Bendix brake booster it's supposed to be a manual re inforcement plate not a power.
My apology on any confusion.
Quote from a seller on E bay that sells quite a few of the Hemi bendix boosters on e bay.
Hello,
Yes it fits the manual brake plate. All you need is the plate, Master and the C or B body booster one would already have.
Here's a power one.
http://cgi.ebay.com/ebaymotors/MOPAR-70-4-CUDA-CHALLENGER-POWER-BRAKE-REINFORCEMENT_W0QQitemZ260210579937QQihZ016QQcategoryZ10076QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
The manual one has additional holes and the center hole is kinda triangular.
« Last Edit: February 11, 2008 - 08:45:24 PM by Topcat »
    • Challenger Gary
« Reply #10 on: February 12, 2008 - 09:53:58 AM »
Anyone know if this is the same one used in a 72 Satellite?
« Reply #11 on: February 12, 2008 - 10:06:24 AM »
The B and/or C body ones have like a 45 degree slant on the top I believe.
E bodies are square with a small notch on one edge. That, I know for sure.
« Reply #12 on: February 12, 2008 - 10:10:22 AM »
One more thing to make it even more confusing. There are 4 patterns of re inforecement plates that I know of.
1. power square..4 holes only, short in size
2. manual square...6 holes, triangular hole in middle
3. manual square...6 holes, round hole in middle
4, slanted top...B and/or C bodies.
